Fog light bulb (front) removal help
Detector Jan 7, 2009
  1. Detector
    Detector Just waiting for the green light
    131
    Hi guys, 3 weeks ago went through VERY deep water, did a first class impression of the Ark Royal followed by clutch slip and a fog light full of water (won't try that again).
    I'm going to remove the bulb and stick a 500w halogen work light in front of it to warm it through after draining water first, when fully dry pop the bulb back and it should be OK.
    Now, that very handy hand book :readit:has no mention of bulb changing anywhere:think: can anyone help pls.
    Oh & Happy New Year to you all
  2. dmor8
    dmor8 New Member
    hey, i've been looking in to this my self and all i could come across was this
    http://www.jmaguire.com/blog/2008/09/15/
    Its for an A4 avant but by the looks of it is the same as an A3 (im sure someone can confirm)
    hope it helps
    dave
  3. alfiejts
    alfiejts Member
    352
    Its easy. In the black grill covering the fog light you will see two cutouts - one at the top and one at the bottom.
    You put a flat screwdriver or similar into these and squeeze together to release the plastic clips - and at the same time gently lever the black grill out from the opposite end to the actual fog light.
    The black grill just pops out when you release the clips.
    After that, the fog lights are held in by three torx screws which are exposed when the grill is removed.
    The foglight itself has a black plastic cover at the rear which then clicks off to reveal the bulb....
  4. Neil C
    Neil C Active Member Audi A3 S-line owners group Team Brill Red TDi Manual
    265
    172
    43
    If you've got to go to the trouble of removing everything, why not just put the whole fog like ( with the bulb removed ) into the airing cupboard. This should gently dry it out, and save having to use the work light.
