Fog Light as DRL - can it be done?
mathu May 5, 2012
  1. mathu
    mathu Member
    116
    hey guys can anyone help, i want to use my fog lights as DRL and i read somewhere that you need to enable it on:
    Module 09 / Byte 17 but when I got into my car it only goes up to Byte 16
    does anyone know the reason for this?
  2. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Why do you want your fogs on as DRL?
    I have the option in my MY2009 car
  3. NHN
    29,328
    1,708
    Please dont open multiple threads on the same subject, as replies get answered in both & it becomes almost useless to others who ask the same questions, please keep it all in one, I'll ask a mod to merge or close one if nobody has replied to other.
  4. quattrojames
    14,050
    576
    I've deleted the other one.
  5. mathu
    mathu Member
    116
    see that is what was expiating to find with my car but my car stops after Byte 16 and i can't seem to enable this feature
  6. NHN
    29,328
    1,708
    Thats cause you have a lesser byte module, so forget it as the newer modules are hundreds & no guarantee will work for you.
  7. mathu
    mathu Member
    116
    thanks for the heads up buddy, but do you have any idea of part number to look out for incase i find one?
  8. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Why..? Its illegal to drive with fog lights on when its not foggy.. And you just look like a cock.
  9. Rhyso
    Rhyso Well-Known Member
    1,482
    304
    You can reduce the brightness of them
    I've run them as DRL's for over 12 months without issues and they are not as bright as the newer DRL's you see on most cars these days
  10. mathu
    mathu Member
    116
    thats exactly what I'm trying to go for but seems like i can't its a shame, but i still would like to know if its possible with new module and the part number
  11. slade777
    slade777 Member
    763
    Not illegal if they are set to DRLs like the new polo and standard C class that doesn't have leds. Both use dimmed fogs as DRLs.
  12. audicruiser
    audicruiser Audi Heaven
    1,865
    Mine are set the same as Rhyso's and I've had no issued and went through MOT with it set...
  13. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    569
    149
    43
    Fogs on in daylight, DRL's or not = epic fail in my book. I'd rather drive with dipped headlights as Volvo have for donkeys, rather than look a plonker. I find them too aggressive as so many bad drivers have their fogs on and I personally would not want to associated with those drivers.
  14. audicruiser
    1,865
    Thats why they are set dimmer than when used as a fog light, and also the new Volvos uses the fogs as DRL too now but with LED technology....
  15. Helifella
    569
    149
    43
    Yeah i've seen the new V50's with the LED DRL's, I nearly adapted mine to freshen the front up, then I ordered the A3 instead :)
    I think because they look so different due to the LED tech Joe Bloggs sees them as DRL's and not just the fogs.
    Maybe it would look better if they could be done for the thread author then fit H11 / H7 LED alternative lights in the fog housing.
    I know fitting LED's to use as fogs doesn't give enough light onto the road but to have them as DRL's would be fine as I think LED's catch your eye more than OEM bulbs.
