FMIC setup A3 8L correct or not?
Jay A3 Apr 22, 2012
  1. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    Looking for advice as per the title
    I have looked through a fair few FMIC threads and most refer to those who buy FMIC kits like forge and ebay ones...
    I wanted to buy the toyosport intercooler rather than the larger ones like AH fab (bit overkill as my power would not require large cores) which meant i needed to buy my own pipes. I didnt want to buy those intercooler pipe kits ebay sell as i wanted the silicone hoses to be 4 ply silicone hoses. Adapted from the list Prawn posted up a while ago in the FMIC thread.
    Im a complete noob when it comes to fitting this in so I have drawn this up to try and show you how i plan to fit this in.
    What i also noticed is the little mention of the pipework for the DV & N75; and how welding might be required in some instances.
    Can anyone confirm i have everything covered, do i need more pipes or re-arrange any pipes?
    Planned setup
    Hotside
    Welding
    Advice appreciated!
    Markeyboy and deeman88 like this.
  2. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Looks correct apart from the top hose goes down instead of to the left. It needsgo down behind the engine onto the turbo. Haven't got a pic atm but ill get one for you tomorrow
  3. Jay A3
    2,130
    356
    Cheers Paradox
    I have re-adjusted the pipe work. I still got the photo of your setup just never seen one mocked up before fitting
    Like this?
  4. Prawn
    11,575
    3,546
    Bingo! Looks spot on Jay.
    POn;y thing you might find is that you could need to trim the first pipe down off the turbo as it'll sit fairly high. apart from that it all looks good.
    Also, you're best off welding the DV and N75 ports onto the first pipe rather than the 45. Keeps everything in a more stock location :)
    DV is the 25mm one btw.
    Should be good once on :) I knocked up my pipework like that in the house too!
  5. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    You will probably struggle to find an 8mm alloy barbed bit for n75, all the ones I could find where steel or brass and ended up turning my own ;)
  6. Jay A3
    2,130
    356
    Thanks prawn
    So weld the n75 and dv into the first 90 degree alloy bend (which I will also need to shorten due to the height of the turbo)
    I will redo the diagram.
    Sorry Stacey what do you mean barbed bit?
    Is that little joiner I got not right? Its made out of (Zinc plated mild steel / zinc alloy materia)
  7. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It wont weld to the ali pipe jay.....:asskicking:
  8. Jay A3
    2,130
    356
    Apart from giving me an ass whipping... Any suggestions?? Lol
  9. Paradox1
    1,833
    88
    Jay i think ive got a alloy hose for the N75 if you need it? I used that chemical metal stuff that prawn used on his and it works a treat.
  10. Jay A3
    2,130
    356
    Gutted I just bought 2 new aluminium pipes. Thanks paradox..
    What chemical metal stuff? What did you use it for mate ?
  11. Paradox1
    1,833
    88
    I drilled a hole in the pipe coming off the turbo. think around 6mm, and put the N75 pipe in there then use4d the chemical metal to create a seat. I got mine of e-bay for about 4 quid. does the job and doesnt leak. check on e-bay for chemical metal or putty
  12. Jay A3
    2,130
    356
    So no welding required? Or is it used after the welding acting as an air tight sealant?
    I will have a look later on eBay
  13. Paradox1
    1,833
    88
    No welding at all bud. Basically drill a whole in the pipe, make sure its big enoughbfor the 6mm tip to fit in bit obviously not too big. The chemical metal feels like blue tack until its hardens. Look at the pix you took of my car
  14. Jay A3
    2,130
    356
    If i cant weld the pipes i will go down the alternative and use the epoxy stuff
    Would something like this be perfect?
    JB Weld adhesive
  15. Paradox1
    1,833
    88
    Spot on bro, its easier use the jb weld as you can do it there and then, no need to get it welded etc
  16. paultownsend
    paultownsend Member
    140
    did you ever get this up and running my friend?
  17. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    so the DV and N75 comes off the first metal pipe after the turbo, so on my k04 it goes silicon joiner off the turbo to the first metal bend, its this metal bend that the DV and N75 go in?
  18. Prawn
    11,575
    3,546
    on your ko4 setup if you're following my guide mate, you'll have a silicon 90 off the turbo then to an alloy 45 degree bend, weld your DV and N75 take off onto the side of the alloy 45 :)
  19. coatesy
    coatesy poking badgers with spoons
    1,920
    280
    i bought one of these : BOOST GAUGE QUICK TAP FOR ANY CAR KKK K04 KO3S GARRETT | eBay.
    and just put it in the silicone coming off the turbo, they were not a tenner when i bough one though, maybe you can get one for cheaper. it doesn't leak so its all good.
    as for the dv it goes on the first metal piece like you are saying, unless you have a dv cold side relocation.
  20. paultownsend
    paultownsend Member
    140
    yes i was looking at a quick tap and cold side relocation to simplify things.
    i also wanted the smaller cooler as im only running a k03 AGU.
    i just didnt want the car being off the road waiting for different pipes to arrive
  21. Johnney1985
    Johnney1985 New Member
    19
    Hi Jay,
    How did you get on with this install? im looking at doing one on mine and i have seen your car in my area. can we arrange to meet up so i can take a look.
  22. Jay A3
    2,130
    356
    All up and running, (completely forgot to update this this thread) Sorry...
    The hotside was easy enough to install, i am still tweaking it till this day to fit it perfectly (might be my OCD kicking in)
    I think i had ordered an extra 45 Degree ali which i didnt need in the end but i rather has spare than not enough. :thumbsup:
    As for the cold side, i had followed prawns FMIC guide, the only thing i changed was the 90 degree ali that joins onto the OEM pipe that goes into the Throttle body. I used a 135 degree ali pipe instead so it would hug in as close as possible. If i was to redo it again, i probably would buy the DV relocation kit as the Turbo / N75 area can get a little bit tight.
    Any time fella, just pm me
  23. phil miller
    1,211
    166
    sorry mate yes i am following your guide, still waiting on my pipes :( so i cant mock it together to get it clear in my head atm
