FMIC Help
and32 May 20, 2009
  1. and32
    and32 Member
    42
    I have bought an fmic from ebay and wondered if anyone has fitted one, i have looked at other threads and have got some info, two things i would like to know are there dosnt seem to be an opening on the new pipes for the n75 take off, theres one for the dv, does anyone know how i can fit the n75, could i use a t piece. The other thing is will my car have a map sensor its a 1999 a3 1.8 t sport thanks
  2. Dani_B19
    9,293
    384
    You got alink to which kit you've bought?
  3. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,197
    2,013
  4. and32
    and32 Member
    42
    its the turborevs kit
  5. and32
    and32 Member
    42
  6. Dani_B19
    9,293
    384
    Does the kit look good quality and have they provided you with brackets to hang the fmic?
  7. Dani_B19
    9,293
    384
    Is that the said fmic voorhees?
  8. Westy
    Westy Well-Known Member
    17,443
    1,104
    No this is the kit:
    And32, looks too good to be true for the cost but I'd love to know how well this cooler works when you finally get it fitted.
  9. 1animal1
    9,978
    i dont follow what your asking AND32....the dv and N75 are mounted on the TIP...the FMIC kit doesnt offer a pipe from the air box to the turbo becauses its an FMIC kit - am i missing something here??
  10. Dani_B19
    9,293
    384
    So the n75 valve connects to the tip, is it the bottom small connection cloest to the turbo?
  11. <tuffty/>
    21,253
    3,880
    Tim, the piping kit looks like it replaces the A3's existing charge side pipes which is why he asks. The one pipe in the picture looks to have an outlet for the DV as stated but not the N75. I am not familiar with the charge piping on an A3 as I have an S3, most kits for the S3 pick up from the OEM SMIC's so that maybe where the confusion is here.
    @And32, I would have a look at using as much of the OEM piping as poss initially to get the FMIC fitted then look to fitting whats left if you can. The other thing I noticed and may be an issue is the MAP sensor... on A3's that have them, its mounted in the top header of the OEM SMIC iirc and there doesn't seem to be provision for that either.
  12. JasonKal
    JasonKal Member
    118
    I have the exact same kit on mine! it took a few adjustments but its fitted and seems to be working fine! Jump on my website below for a few pictures, mines fitted to a K04 turbo im not sure if it would be easier on the standard K03
    I will try and get Rich (the person that fitted most of it) to jump on here and help out
    any questions let me know and i will try and help
  13. 1animal1
    9,978
    cheers Jase, awww **** you have to lose the fogs....
  14. JasonKal
    JasonKal Member
    118
    I never had Fogs on mine at the bottom anyway, mine are in the main headlight for some reason ?? not sure if thats normal but when i pull my light switch out the fogs come on in there
    Im thinking about getting some custom pipes made up so that i can tuck the pipes in a bit more as they do stick out a little bit. I want to be able to get some grills put back in there to hide it all away
    What do you guys think ?
  15. 1animal1
    9,978
    yup agree it needs tucking in, perhaps cutting the pipes at the joins to the OEM pipes and get some longer sleeves maybe.....
    erm, the 1.8T's have fogs in the light cluster...as far as i know all S3's have fogs in the grills..never seen one otherwise pre face or post face
  16. 1animal1
    9,978
    out of interest have you noticed the difference much?
  17. JasonKal
    JasonKal Member
    118
    Difference with the FMIC ? I cant really tell you if im honest cause all the work got done on my car in one go. It went from a totally standard 180bhp 1.8T then we added the new K04 turbo, S3 injectors and downpipe etc with the Exhaust and FMIC on there aswell. So i couldn't really tell you a difference but its all working together nicely :D .. just want a better re-map done really im sure its got more to give !
  18. Westy
    17,443
    1,104
    I knew it would be too good to be true!
    Does anyone have the exact measurements of all pipes and the core that comes with the forge kit? Surely someone has tried to source their own pipework?
  19. and32
    and32 Member
    42
    thanks for all help i will try and fit it this weekend then, oh yes how much cutting of the bumper is needed to get it to fit
  20. markyR
    markyR Member
    118
    i would also like some help with what to do with the n75 valve and dv pipes that connect to the charge pipe on the back of the engine.i've looked at some of the pictures in your web site of your quattro but cant see much maybe someone has some deatailed pictures of what to use please? cheers mark.
