Fmic + fog lights
indiemike Nov 17, 2009
  1. indiemike
    indiemike ZoomZoom
    388
    Hi just a quick question, When fitting a fmic I've seen several people on here remove the fog lights and insert pipe work in it's place. Are the front fogs needed for a mot pass??
    Thanks mike
  2. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    They are not "needed" as such for an mot.
    If they are there they have to work was all i have ever been told.
    So removing them isnt a problem.
    If your fitting the Forge kit ( as it says in your sig )
    you dont need to remove them, The kit is designed to fit around/behind them.
    Personaly i would leave them in if your going with the mentioned kit as you would be loosing something you dont need to. I made up my own pipework and realy wanted to keep the fogs so had to work realy hard to sort the pipework around them.
  3. indiemike
    indiemike ZoomZoom
    388
    I just seen some pics of a s3 running a forge fmic a while back and seen the pipes in place of the fogs and liked the look of it. But might just keep it stelf like and keep the fogs inplace
  4. Broken Byzan
    13,237
    465
    If they are fitted they need to work, if they are not there, they cannot be tested.
    Check out the Ebay/Forge/Ah fab FMIC thread for details
  5. indiemike
    indiemike ZoomZoom
    388
    cheers 4 the help, think when I get it sorted I'll keep them in place. Will have 2 wait till the new year now, thinkin I'll get the turbo and fmic done at the same time so time 2 start saving lol
  6. S3 Paul
    2,825
    107
    Should be a little flier then !
    Saving is always the hard part
