Flywheel problems.
choimaloy Apr 8, 2010
  1. choimaloy
    choimaloy Member
    111
    In january I had my flywheel and clutch changed now the car at around 1500 to 1800 revs jerks/judders like hell when I put my foot down then it goes when i reach 1900 revs,its a 130 tdi 2002.I had it back to the garage who fitted it and he says its the flywheel,as I sourced the parts myself they are Sachs parts i spoke to the supplier and he said that its not the flywheel.Is it possible to get faulty flywheel and would it cause this problem.
  2. simon.m
    simon.m Active Member
    2,747
    id think you can get faulty one but the garage that fitted it are saying its that id have thought they should have seen it before they put it in?
  3. wand106
    wand106 New Member
    Out of interest does it only do this on load, or does it judder around 1500-1800 rpm in neutral? I have a similar thing but I have V6 2.4 petrol, and have been told flywheel, or crank shaft pulley. Flywheel and clutch oem parts £1450 so I'm having a careful think..... Crank shaft pulley is being done with the cam belt next week, so see if that helps.Its only done 42k!!!
  4. wallacr
    wallacr Member
    260
    When I bought my 2001/51 TDI 130 a few years back I had the same symptoms, they thought it was the clutch and flywheel and replaced them on warranty, but it was still there. In the end they put it into Audi and they diagnosed it to be a faulty injector and it was ok after that. I've done about 60k without the fault reappearing.
    Rich
  5. choimaloy
    choimaloy Member
    111
    no its just under load and really bad between 4th and 5th.
  6. wallacr
    wallacr Member
    260
    That was the same more me, I noticed it most when cruising on the motorway in 5th and then I wanted to overtake.
    Rich
  7. choimaloy
    choimaloy Member
    111
    how much did it cost for the injector?
  8. wallacr
    wallacr Member
    260
    I had mine fixed on warranty, so I'm not entirely sure, but I think they are about £400 each. Have you tried cleaning them with something like Red Ex? Not sure if it will help, but worth a try.
  9. simon.m
    2,747
    they are about £500 if you get trade mate
  10. legin
    legin Member
    76
    Hard to damage an injector when changing a clutch but easy to damage a harness which is a well known weak point on the engine anyway. Good news is its cheap and easy to replace, I would go there first.
  11. simon.m
    2,747
    sorry whats the harness your talking of mate
  12. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,399
    2,943
    Like the man said, what is the harness to which you're referring?
  13. legin
    legin Member
    76
    The wiring harness in the cylinder head that runs to the injectors. Do a search and you will see.
  14. simon.m
    2,747
    i tried to find it and can not :sorry:
  15. technics100
    technics100 Active Member
    850
    25
    I had a misfire in mine and it was caused by the harness, I took the plugs off each injector, cleaned them and re-crimped them and re-fitted. solved my problem. A new harness is only £40 from Audi.
  16. T0m
    T0m Active Member
    516
    26
    I had the same problem got the flywheel replaced and clutch replaced under warranty and it was still there, Audi told me you need to drive it in but it was still there and it went back in and had another new one and it was sorted so it is possible to ge ta faulty new one!
