Flywheel options
dave5551 Oct 21, 2013
  1. dave5551
    dave5551 Work in progress
    54
    What's better for my s3 dual mass or solid mass flywheel
  2. superkarl
    superkarl MAN OF STEEL
    9,287
    2,295
    Define 'better'
    Ambiguous question
  3. boost-addict
    boost-addict Well-Known Member
    1,000
    "better" by the means that the car will rev easier and release a little bhp
    but you will get noisey or rattly nosies at idle
    dmf and smf have there pros and cons
  4. dave5551
    54
    Yeah by the means of a bit more bhp the 3 av got is a work on progress bit it's soon to be running around 350 bhp
  5. MexxT
    MexxT Member
    31
    I have a Spec billet flywheel in my S3. the noise is acceptable when the AC is off. If AC is turned on, it rattles like a mofo...
    The only thing is, that you have a lot more noise and vibration when you are breaking on the engine.
    But in combination with a Sachs organic race clutch (I have the one without springs in it, zo no dampening at all) it drives awsome. launches @7000rpm go flawless. And you can drive normal.
    Jason.s and s3dave like this.
  6. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    i didnt know the SMF was avil for us Quattro boys, anyone have any links as my DMF has started to knock
  7. MexxT
    MexxT Member
    31
  8. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
  9. Andrew@A.L.D
    3,869
    607
    TTV flywheel is about £100 cheaper Dave
    When i got mine it was £220 but i think there £300 now
    s3dave likes this.
  10. s3dave
    10,110
    736
    Thanks i will have a look...
  11. Chazaxl
    Chazaxl New Member
    29
    Im looking at a stage 2 clutch (from cg.motorsport) for my soon to be remapped 8L S3. Any one have one of these already? What are they like - how much 'stiffer' than standard?
  12. Chazaxl
    Chazaxl New Member
    29
    Mmm, my research tells me that Kevlar is a bad choice for those of us that need to do stop / start traffic - there is a chance of overheating the Kevlar it seems - if this happens, the clutch can be toast. Might just stick with LUK / OEM.
  13. Nyteryda
    Nyteryda Nyteryda
    234
    ecs stage 3 clutch and fidanza flywheel here .. rattling at idle has got better since gbox fluid additive was put in, but still noisy as a motherfo when engine breaking which i personally find pretty annoying for a road-car
    apart from that it grabs nicely and the pedal motion feels like stock
