  1. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    best thing to get the lil fukkers off with
  2. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
    bug and tar remover meguires stuff is good im sure john from pb will outline some great products
  3. John @ PB
    John @ PB Member
    360
  4. Syvo
    1,338
    22
    all ways good products made by poorboys
  5. StateOfPlay
    StateOfPlay Well-Known Member
    2,250
    190
    If you have waxed the car, standard car shampoo will do the job. If it is a right sticky little ****er, try wd40 or T-Cut.
  6. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    No to TCUT and No to WD40..
  7. h5djr
    9,174
    1,574
    Strange but I've found the best way to remove flys is to drive through a heavy rain storm. No always practical I know.
    When I was driving back across France from a holiday in Germany the front of my car was covered in insects. Then it decided to chuck it down with rain and the next time I stopped they were no inspects at all on the front of the car or the screen.
    The other method I sometimes use is, horror of horrors, put my car through a car wash. That has the same effect and I can choose when I do it.
  8. The Doctor
    The Doctor Well-Known Member
    1,396
    189
    Just keep your car waxed and they should just wash off fine with some warm water & a good quality car shampoo. No way would I be restorting to T-cut, WD40 or car washes personally. Maybe you have extra-sticky bugs in your neck of the woods.
  9. FranA3
    FranA3 events moderator Regional Rep Gold Supporter Audi A3 Team Brill Red
    7,216
    304
    as the doctor says if your car is well waxed then there would be no need to resort to anything harsh all i do with mine is jet wash it and they are all gone sometime need to wash if with a mit but most of the time just water works just fine but then again my car is caked in wax lol
  10. StateOfPlay
    2,250
    190
    Ah well, each to their own, WD40 has worked for me, so has Tcut, saves spending money on a product that does the same thing. As for damaging paintwork, well, wd40 is a ****ing lubricant, so will not cause any harm. T cut just removes a fine layer of paint. People have used it for years and years. Some people don't know how to use it, so they probably need to spend more money on a product that does the clever stuff for them.
  11. FranA3
    7,216
    304
    ive never heard of wd40 being used for rly's but if it works then happy days , i wouldnt really want to take a small layer of paint off thoi just for flys as they are on there all the time in summer so i wouldnt want to do that too often wouldnt have any paint left in a few years lmfao
  12. FranA3
    7,216
    304
    thats one way i suppose lol
  13. tdia4
    tdia4 TDIPOWARRR
    613
    Autosmart G101 at around 1:3 will take them off easily.
    But give the car a wax and they will come off with just a wash no problem.
  14. John @ PB
    John @ PB Member
    360
    WD40 is, technically, not a lubricant, it's a water dispersal product. It will remove flies, but then so does Tardis (tar remover) - it's quite heavily petrochemical laden.
    G101, if you want to use it, use it at 30:1 - 3:1 is way too strong; you could stain plastic trims permanently at 3:1. 3:1 will degrease engines with ease.
    T-Cut will work - but it's very aggressive, you'll be removing paint and you'll end up with a hazy finish as the abrasives in it don't break down.
    It'll work, but it's like wiping your backside with sandpaper.....
    RYes3 likes this.
  15. tdia4
    tdia4 TDIPOWARRR
    613
    Never had that problem with G101 myself, used it straight in the past, just on front bumper and wingmirrors, leave it 2 minutes and pressure wash the flys off, stopped doing it though as you can expect it was working out pretty expensive.
  16. StateOfPlay
    2,250
    190
    I have to ask....................how do you know that
    :w00t:
  17. hades-
    9,480
    646
    im thinking hes kinky
