Fluuuuuuuussssshhh! :-)
OVRA3 Mar 22, 2012
  1. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    Guys I am sure this has been asked before but I cant seem to find a link to it so if anyone can help I'd appreciate it!
    Realised recently that my car has blue coolant in it and it should be pink, its due a service but thought if its easy to do I might just flush the coolant and fill with G12 myself, whats the easiest way to do it myself?
    Cheers guys! :)
  2. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    570
    154
    43
    Food colouring??? :whistle2:
    OVRA3 likes this.
  3. OVRA3
    1,079
    80
    I like it if no one responds soon I might just do that! :jester:
  4. OVRA3
    1,079
    80
    Bump
  5. mjr901
    mjr901 Guest
    take bottom pipe off the radiator and let it all collect in a bucket and dispose of it properly. Normally its one of those spring tightening jobbies that you need a good pair of pipe grips for or large pliers holding the pipe on. 15 min job tops.
    Bleed the system after.
  6. OVRA3
    1,079
    80
    Cheers MJR901, right I am a complete beginner! How do I bleed it?
  7. mjr901
    mjr901 Guest
    well I just fill to max level, then switch car on.
    the level will then slowly drop as its being pushed around the engine, keep filling to the max level until it doesn't drop any more.
    go for a spin for 10 mins. check level.
    top up if necessary.
    just make sure what you take out is roughly what you put back in. :)
    OVRA3 likes this.
  8. OVRA3
    1,079
    80
    Nice work, sounds easy, I'll give it a go!! cheers for the advice!
  9. mjr901
    mjr901 Guest
    don't forget to put pipe back on securely before you refill! else your gonna be scratching your head!
    OVRA3 likes this.
  10. dex140
    dex140 Member
    223
    I recently changed the rad on my car and has some issues diconnecting the bottom hose of the rad, the clip is easy to undo but the joint is plastic on plactic and did not come undone very easy at all, as i was removing the rad anyway i had to half take it out of the car before i could disconnect it!
    If its not stuck on it will be really easy, just a case of pulling the metal clip up till it clicks then pull it of the rad, to refit push it back on and click the metal clip down!
    Mine is a 2.0tdi btw!
  11. dex140
    dex140 Member
    223
    In terms of G12 when i had my seat i bought some from the dealer**** which cost a fortune...you can buy other antifreeze that conforms to G12 spec for a fration at of the price!
  12. OVRA3
    1,079
    80
    Awesome I'll give it go and see what happens worse case its in for a full service next week so if it doesnt go to plan then I'll get them to sort it!
    Cheers buddy :0)
  13. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,078
    62
    Go to your nearest Skoda dealership for a better deal on G12.
    OVRA3 likes this.
  14. FranA3
    FranA3 FMDETAILING Site Sponsor Regional Rep Gold Supporter Team Brill Red Audi A3
    7,264
    363
    I've been thinking of doing this for a few weeks and replacing it with the pink coolant I'm guessing it would be the same on my 1.6 with regards to the rad pipe
  15. mjr901
    mjr901 Guest
    Should be roughly the same with all cars,
    Even on my mums old tatty 1986 old banger Toyota Carina II its the same technique :) although, it doesnt take the pink... it likes the older stuff :)
  16. FranA3
    7,264
    363
    haha good stuff will get some in a few weeks and get it done thanks buddy
  17. OVRA3
    1,079
    80
    Was having a look last night and I cant get to the radiator from what I can see because of the front spoiler, it seems to go right under the bottom of where the radiator is? Might have to get them to do it with the service as I dont think its going to be easy to get to unless anyone knows better?
  18. dex140
    dex140 Member
    223
    Did you go in from the engine bay? Thats how i did mine...bit of a squeeze mind!
  19. OVRA3
    1,079
    80
    Ahhh no I was looking for underneath, only had a quick look after work, Ok i'll have another look in the morning and see if i can get to it! Can imagine its a bit tight in there.... :p
  20. dex140
    dex140 Member
    223
    Yeah it is quite tight...but i have rather thick arms and i managed to get my hands down there!
  21. OVRA3
    1,079
    80
    nothing a bit of lube wouldnt sort out :ohmy: this conversation is going well off key ha ha..
