Flutter noise when lifting off throttle
SCHOLESY83 Jul 4, 2013
  1. SCHOLESY83
    SCHOLESY83 Member
    42
    Thought I had this solved, after reading its likely a diverter valve fault (dump valve). I've took my old one off expecting to see a damaged diaphragm but it all looks fine?
    Can anybody help here?
  2. Bullys3
    Bullys3 Member
    191
    20
    Could have a vacuum pipe pop lose I had the flutter once on my Astra vxr and it was vac pipe, I could be wrong but worth checking out. There could be a tiny hole in the diaphragm in the diverter valve that you can't see as its rubber
  3. SCHOLESY83
    SCHOLESY83 Member
    42
    I would have looked at the vac pipes however there doesn't appear to be any, this diverter valve appears to be electronic?? How does that work? Does it work of pedal position or something? I just haven't got a clue.
  4. SCHOLESY83
    SCHOLESY83 Member
    42
    Problem fixed - it was the diverter valve. Must have been the solenoid inside it which went faulty.
  5. Bullys3
    Bullys3 Member
    191
    20
    Glad it's fixed did you just buy a new valve ?
  6. SCHOLESY83
    SCHOLESY83 Member
    42
    Yup.
  7. gilberto
    gilberto Member
    156
    Does the car feel any different now?
  8. Adamj
    Adamj Member
    94
    Mines stage 2+ and sounds like a turkey. Everytime on boost is it normal?
  9. gilberto
    gilberto Member
    156
    I'm getting like a flutter sound on boost in the higher gears, not sure if its normal or not. what does yours sound like? By turkey do you mean flutter?
  10. Adamj
    Adamj Member
    94
    Yeah and also like a mid-high pitch noise
  11. gilberto
    gilberto Member
    156
    I'm going to get the Rev D Diverter Valve, see if that makes a difference.
