Flute Noise
AVLO Jul 4, 2013
  1. AVLO
    AVLO Active Member
    295
    52
    Hi folks earlier today I had the windows down whilst driving round my village and I have noticed a strange noise once boost is built up then let off. It just sounds like someone blowing through a flute. It seems too hold boost fine but this noise is now starting to worry me as I've never heard it before :think:
    has anybody else had a similar noise?
    thanks
    matt
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    What DV have you got Matt?
  3. AVLO
    AVLO Active Member
    295
    52
    I've got a 007p with yellow spring. I'm using a std air box with panel filter but it sounds like a flute sound dump valve????
  4. s3dave
    10,110
    736
    Have you got the revised piston in it? or just take it off and clean it, it may need re greasing?
  5. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,920
    756
    only time this happened to me is when the intake pipe popped off my K&N cone filter, checked all the obvious things (hoses still connected etc)?
  6. Rice
    Rice Active Member
    247
    37
    Does it sound like this? As I'm a little unsure of the noise you're referring too.
    Sam_ likes this.
  7. Rice
    Rice Active Member
    247
    37
    In all seriousness... I have this noise coming from my s3 too, it's only when I have the throttle in a certain position and keep it there, usually around 2-3k rpm. I have a standard 710N dp which is about 2 months old, been doing it for a while! Just thought it was an odd vibration of something.
  8. Lavis89
    1,920
    756
    possibly the d/v piston getting stuck open?
  9. Rice
    Rice Active Member
    247
    37
    Maybe, but I was at r tech yesterday with it on the rollers and he didn't say anything about it. Could be that it's only at a certain pressure but it would stay open then and I wouldn't get any boost.....
  10. AVLO
    AVLO Active Member
    295
    52
    Haha rice it didn't sound exactly like the video you posted haha, but too confirm it is defiantly the dv that is causing the noise as today I've used another 007p that I had at one side. This also has a yellow spring but has only done about a 1000 mile and by trying this I no longer have the strange noise
    happy days, oh and rice I would have a look into the dv I'm not 100% sure what to look for to see if its ok personally, but I'm sure someone else may be able to help you out.
  11. S3quatt
    S3quatt Flat Oot like a ducks Foot VCDS Map User
    652
    60
    LMFAO!
    You beat me to it!
    My question was going to be "does it sound like jazz flute?"
  12. Rice
    Rice Active Member
    247
    37
    Had a trip out and was keeping an eye on my boost gauge, the noise was happening between -5 to -2. I've got an old dv somewhere that ill try out later.
