Fluid levels
nally Sep 21, 2013
  1. nally
    nally MPG the new BPH
    2,104
    34
    Hello Fourm
    i have been checking my levels and I think my water may be a bit low
    it was serviceed 11k ago and had and oil change around 5k ago.
    the marking on the manual is a different type to the acctual one.
    here are some pics
    Style pictured in the manual
    One i have in my car, the level sits about half way above xxxed area above the min line ( please see bottle markings below)
    is this too low or just right ?
    thanks nally
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Bottles look the same shape and capacity.
    So use the top bottle as the marker for where the max level should be.
    I'd say if the level is about 20mm above the central seem, then level is spot on.
    Any lower then the min line, then add the pink additive.
  3. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    Fill it up to the seam half way of the bottle.
  4. nally
    2,104
    34
    Thanks guys thought it looked low as I have the second type of bottle there is mo maximum line seems mad.
    Is it just antifreeze ? I add
  5. Chillout
    Chillout Active Member
    609
    50
    Is the engine at ambient temperature when you check the levels ?
  6. MrLapou
    1,233
    121
    Yeah you should be okay adding neat pink coolant additive. After all winter is on it's way.
  7. MrLapou
    1,233
    121
    Yes
  8. nally
    2,104
    34
    It was cool when I checked
