Flickering Xenons, bulb or ballast?
GrantP Oct 24, 2013
  1. GrantP
    GrantP New Member
    21
    Hi all,
    my passenger headlight has started flickering, sometimes goes out completely for a few seconds then back on and flickering again.
    i understand that this could be either the bulb or the ballast (electrical box thing).
    does anyone know of an easy way of identifying if it's the bulb or ballast thats the issue to save me having to take the headlight out twice?
    Thanks in advance.
  2. Big Al
    Big Al Active Member
    489
    68
    Hi mate
    Having experienced the same with my car in the past, I'll bet it's definitely the bulb. I spoke to many companies at the time and they all said change the bulb first. It's cheaper and solves the majority of flickering issues. I was told if the ballast fails that the bulb generally stays out or struggles to light up. Alistair
  3. GrantP
    GrantP New Member
    21
    Thanks I'll a get a bulb ordered up
  4. Giosabcsl
    Giosabcsl Active Member Audi A4 saloon
    853
    156
    43
    Im having the same issue on my audi. And almost 90% of the time I have been told its the bulb.
    The easiest way to tell is if the unit is still emitting light even when it goes "dim" then its definitely the bulb.
    If you get a bulb out warning on the dash that could be most of the time a blown bulb. In which case you wont get any light at all.
    There is a bloke on our forums named T8ups. He sells the D1s bulbs Oem or uprated to 6000k which is a nice bright white. And is a lot cheaper than the retail products out there. As a D1s bulb is cost around 80-100 ea.
    Just a thought
  5. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Had the same issue except mine would only flicker briefly. Got some 8000k D1S bulbs from T8ups as I was after the blue tinge.
    V6 Quatt likes this.
  6. V6 Quatt
    V6 Quatt Well-Known Member
    1,248
    441
    How much for the Set of DS1 need to change one of mine lol
