FLAT SPOT PROBLEMS?
nell.l Oct 10, 2011
  1. nell.l
    nell.l New Member
    21
    hi,can any one help me,i have a 2005 8p 2.0tfsi with a remap.i'm having a few problems when accelerating through out the rev range the car suddenly hesitates a couple of times like a flat spot.
    any ideas thanks.
  2. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    sparks plugs and possibly coil packs almost definately!
  3. nell.l
    nell.l New Member
    21
    I'll try plugs first i think some descent one's,cheers.
  4. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,326
    188
  5. nell.l
    nell.l New Member
    21
    Haha iv noticed the club an joined it,the remap was done by more Bhp, cheshire.
  6. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3 It's my birthday
    3,078
    605
    Hi also have flatspots running stage 2 + revo ... I have put in new plugs in oem and coilpacks,back to the tuners me thinks...
  7. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    another member if the flatspot community. try replacing your maf sensor,if not then your n75 valve
  8. Kelza
    3,078
    605
    Hi you mean the revised d diverter value , i,m sure if the maf sensor was faulty it would show a fault via vagcom...
  9. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    What is your mileage?
    Have you got any other modifications?
    Think it may be worth going somewhere where they can do some logs and see if it's boost related, or whether other parameters are out. Might cut out a lot of cost and guesswork.
  10. Kelza
    3,078
    605
    Hi warren it has 27 k on clock all the usual stage2 +mods would not know where to start looking via a rooss tech cable , i have checked via sps revo switch making sure the ecu works with the switch etc all fine , have been out on 2 other stage 2+cars and they are totally different to mine ,one with revo one with giac map they full on and keep pulling where as mine is hesatent And feels flat in other words it does not blow your mind ...
  11. warren_S5
    7,210
    2,487
    S3kel, have you uprated clutch?
  12. Kelza
    3,078
    605
    No warren the clutch is fine no slipping etc, i have the sachs one here ready ...
