Flat Spot 3.2
edition Nov 1, 2007
  1. edition
    edition Active Member
    1,426
    Hi,
    1st poster here with a new car (new to me). I have just bought a 05 plt a3 3.2 s-line and think i might have a problem.
    It seems to have a flat spot upto about 2k as above 2k there is a noticable step up in smoothness and power.....
    Is this normal?
    Other than that im very happy!
  2. Wes G
    Wes G Member
    444
    I had a flat spot on mine a bit higher in the rev range (2500-3000) which I eventually found was the little plunger had come off the end of the inlet manifold...if you open the bonnet and look down towards the rad on the right of the plastic maifold you will see what i mean, its a little vacuum unit with a little plunger coming off it to the end of the manifold...Not sure how it works but I think it opens the valve in the manifold when under load?...might not be your problem but worth a look as it had fallen off on mine somehow...?:icon_thumright:
  3. Wes G
    Wes G Member
    444
    Oh & welcome to AS:salute:
  4. edition
    1,426
    Thanks for the help will have a look when i get time! Just dont know if thats how they are...
    Only other problem i have is that when going slowly and putting on full lock quickly i run out of assistance. Is this normal?
    Cheers!
  5. Wes G
    Wes G Member
    444
    If your car is still under warranty then get it to a dealer to sort...it was a common problem on the 3.2 and a new rack was the cure I think, mine was done under warranty but I still get the problem even now,although not as bad as before...if its not under warranty then I wouldnt worry, you`ll get used to it.:icon_thumright:
  6. TDI-line
    TDI-line Uber Post Whore Team Floret Silver quattro Audi A3 Black Edition TDi
    9,503
    1,133
    Might be a software issue. My Mk 4 R32 used to suffer from this, and there was an update on Vag.com, dealer again.
    And welcome.
  7. RobB
    RobB Member
    317
    Had it on both 3.2s I have owned. It's at about 2200rpm. Most noticeable when on a light throttle and trying to drive smoothly and it buggers it up and makes you look like a learner (or is that just me?). Wasn't aware of a cure, but have had a new rack on both cars and haven't noticed any difference - actually why would it help?
  8. Savage
    Savage Savage
    68
    Read post #4 - edition quotes a steering issue. I assume this is what Wes_G was refering to, at least I hope so ;)
  9. RobB
    RobB Member
    317
    Cheers - must learn to read as well as drive properly.
    Steering rack problems are frequent - can go all lumpy if you try to turn the wheel quickly at low speeds. Either that or it makes a creaking noise when turning left. New racks are supposed to cure it but I have had three. The latest one is by far the best but not perfect.
  10. killa_z
    killa_z Couped Out
    180
    excuse me for not knowing but what is a 'flat spot'?
  11. marms
    marms Member
    833
    [SIZE=-1]A point during acceleration when the engine seems to lose power for an instant.[/SIZE]
  12. killa_z
    killa_z Couped Out
    180
    ah, got it!
    will have to check on mine, only got it recently so im still learning it
