flat bottom airbag wiring
bagey Jun 11, 2012
  1. bagey
    bagey aud you do !
    198
    had a flat bottom steering wheel lying around catching dust , so decided to fit it over the weekend to find that my wiring off the mfsw airbag doesnt match the fbmfsw airbag :( . ive had a search and found off other posts that i need part number 8j0 971 589 b , so went to tps to order one and told me that the part number has changed to 8j0971589h . i was wondering can anyone confirm if this is corrrect, before i order one .
  2. Ash187
    7,478
    735
    yes the H is the newer version which works.
  3. Lewbo
    Lewbo Well-Known Member
    1,265
    103
    You need need to buy a new harness can just adapt the current one you have, it's only the horn cables that need adapting, can't remember what colour they were.
  4. bagey
    bagey aud you do !
    198
    cheers lads :thumbsup:
  5. amar06fbr
    amar06fbr Vorsprung Durch Technik
    1,055
    68
    Thats what i did :D
  6. bagey
    bagey aud you do !
    198
    right , was about to buy the cable when i came across one on ebay . came yesterday so had a go at fitting it to the airbag and it doesnt fit ? the connectors are to small ?? anyone know where im going wrong ??, is there another wiring harness ?, has anyone got a picture of the wiring harness to make sure the connectors are right ?
  7. Ash187
    7,478
    735
    whats the part number you got?
    and what wheel have you got?
  8. bagey
    bagey aud you do !
    198
    alrite ash , the wiring loom part number is 8j0 971 589 h and ive got a 2011 s3 wheel according to the seller but looks more like a tt wheel as it hasnt got the s3 badge on it . i havent got the same airbag as you i have the older style one , without the chrome if that makes any difference . theres a bit of suspicious soldering on one of the connectors , which has got me thinking has he changed them ? as none are the right size ?
  9. Ash187
    7,478
    735
    do you have a part number of the wheel? i can try and find out if you have the wrong loom. I am pretty sure you have the correct loom as all of the flat bottom wheels with the round airbags share the same connectors but just in case
  10. bagey
    bagey aud you do !
    198
    its the wiring on the airbag im having problems with ash , obviously the green and orange plug in no bother its the other three wires for the horn etc , the connectors at the end of them are all to small to connect to airbag [​IMG]
  11. Ash187
    7,478
    735
    I know you mean the spade connectors, but they all look right from the loom. Are u sure you are connecting them to the right points on the back of the airbag?i can see one connection point in the pic
  12. bagey
    bagey aud you do !
    198
    Ah right well I know which one you mean as its just below the yellow wire. I thought the other two were at the top , above the two main connectors ? Can u tell me where they go please ?
  13. Ash187
    7,478
    735
    Yh that one under the yellow wire... Put up a better pic of the airbag, maybe a slight bit further away. I cnt remember all 3 off the top of my head but I'm pretty sure there is a small one just under the metal to the right of the yellow wire... Kinda where you now have the black wire tucked in but on the right... And the third one is on the metal on the right side
  14. bagey
    bagey aud you do !
    198
    right i have searched everywhere for anywhere else they could go and keep coming back to the same two ! which the spades dont fit [​IMG]
  15. bagey
    bagey aud you do !
    198
    found a pic on ebay before with wiring harness on it and it definately looks like the spade connectors are wrong ! :(
  16. bagey
    bagey aud you do !
    198
    anyone know where to get spade connectors from ?
  17. Lewbo
    1,265
    103
    Yes they are deffo wrong I used some red spades 0.75-1.5mm I got these from work as I am an electrician but any little hardware shop sells them, or halfrauds.
  18. bagey
    bagey aud you do !
    198
    cheers mate appreciate the reply
  19. 114mph
    114mph Member
    79
    19
    Did you end up fixing this just by changing the spades?
    Im trying to do the same mkii TT wheel on A3, looking at the A3 airbag harness, the horn pin and one of the ground pins are too small.
