Flat battery
stuhow3361 Mar 11, 2011
  1. stuhow3361
    stuhow3361 Member
    210
    14
    Hi guys,car wouldn't start this morning due to a flat battery.Used a set of jump leads to get it going but now my fuel and temp gauges don't work.Could a fuse have blown and if so where do i find the fuse box on the tdi avant b6 and which fuse do i check?
  2. CHRIS555
    CHRIS555 DOPE with added OCD
    1,969
    10
    Possibly. May be worth having the codes checked.
    I know that a friend of mine had a B6 and his battery just went too - with no warning what so ever
  3. scott b
    scott b Active Member VCDS Map User
    1,254
    side of the dash, open the front door look at the side of the dash youll see that the panel will clip out, fuse box is behind there
  4. CHRIS555
    1,969
    10
    Use your car key to pop the cover of
  5. stuhow3361
    stuhow3361 Member
    210
    14
    thanks guys but had to buy a new battery.once this was fitted all the dis faults corrected themselves,including both gauges.
