yes mate will defo be the sensor located in the tailgate. I has same fault on mine and stupid sh!T kept me up all night as alarm kept going off. Boot light would sometimes come on and sometimes go off. By sometime I mean change every couple of minutes or when I drive over a bump. Really annoying but good when fixed
yes m8, look for dampness etc, try using a water displacing spray from halfords etc, maybe a temp fix, the rear washer/arm grommet fails as well on this car, so also check this
hi cal
Ive undone some of the screws on the front of the motor and just pushed some silicon in the joint then tightened up fingers crossed may of done the job alarm did not go off in the night
