flashing glow plug light
madmark Apr 23, 2012
  1. madmark
    madmark Member
    173
    hi i have a a3 tdi sport 110bhp when i started it it misfired then loads of blue smoke and a flashing glow plug light ive replaced the glow plugs and it seems to be running fine glow plug light comes on as normal with ignition then goes out as normal i start the car and it runs fine after about 30 seconds the glow plug light starts to flash car still running fine anyone have any idears what to try thank you mark
  2. Vwdan80
    Vwdan80 Member
    100
    Hi, usually a faulty brake pedal switch will cause the glow plug light to flash, scanning with vcds would confirm it
  3. AudiS3-Turbo
    AudiS3-Turbo Member
    619
    27
    Flashing "glow plug" light does not necessarily mean a glow plug/circuit fault,they come on as said above for brake light switch or all bulbs off,or for injector faults etc.... you need to have it scanned for fault codes or you will be guessing.
  4. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Have you scanned the car? I have just read that brake lights being out can cause the GP light to flash. I wasn't aware of that, I have only had a message on the DIS when a bulb is out.
  5. madmark
    madmark Member
    173
    all bulbs are working fine
  6. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Get it on fault diagnosis software then, other than that it's guesswork.
  7. ruffrida
    ruffrida Well-Known Member
    1,926
    313
    Hi, I had this problem on my A3 110tdi, it turned out to be a bad conection with the OSR brake light, do you still have the old / origanal clocks in?
    As this could also be a warning light for the clocks on the way out, mine caused me loads of problems to the point where the car would not even start.
    I know its annoying but the guys are right it needs going on vag-com really.
