Flashing glow plug light, slight loss of power, lumpy...
t0ph0id
Bristol, UK
My glow plug light has started flashing recently, paired with a lumpy idle, slight loss of power and a bit juddery in 6th on the motorway.
Any idea what this could be? I'm a bit worried about it.
Year of car, 140 or 170 bhp, all info relevant when asking for help.
I reckon it could be your glow plugs.
Are you having trouble starting in the cold mornings, though? That's normally the first indication of glow plug issues.
Nope, starts first time every time. I've been using it all winter, 6.30am starts, no issues.
i have been doing lots of short runs, could this affect it?
Ideally it needs scanning, but when was the fuel filter changed last?
Glow plugs have no relevance when driving at all only starting.
Will arrange to get it scanned, no idea on fuel filter, only had it since June, will check the history when I get home.
Also an injector cleaner may be worth a go, although they're not amazing it may help, egr/imf clean, various options, but scan 1st :)
N8 is sometimes down there, but maybe ask if he knows someone in Bristol with VCDS, say NHN said to PM him :)
These are the results I got from VCDS
I drove to Cardiff and back on the weekend and over 60 it was very juddery, I didn't really want to go over 70 at all.
Code:
VIN: Mileage: 193690km/120353miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 016 FF    HW: 028 101 190 5
   Component: R4 2,0L EDC 0000SG  6337
   Revision: 12345678    Serial number: AUX7Z0DNFNB08C
   Coding: 0000072
   Shop #: WSC 06314 000 00000
   VCID: 6CDDB514361B
2 Faults Found:
17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault
            P0674 - 000 -  -
             Freeze Frame:
                    RPM: 819 /min
                    Torque: 42.0 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.21 V
                    Bin. Bits: 11000100
                    Temperature: 14.4°C
                    Bin. Bits: 10110000
16955 - Brake Switch (F): Implausible Signal
            P0571 - 000 -  -  - Intermittent
             Freeze Frame:
                    RPM: 798 /min
                    Torque: 32.0 Nm
                    Speed: 5.0 km/h
                    Load: 0.0 %
                    Voltage: 14.14 V
                    Bin. Bits: 11000110
                    Torque: 132.0 Nm
                    Bin. Bits:  0 01  1
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0023174
   Shop #: WSC 06435 000 00000
   VCID: 3A71434C0CCF
No fault code found.
Address 08: Auto HVAC        Labels: 8P0-820-043.lbl
   Part No SW: 8P0 820 043 D    HW: 8P0 820 043 D
   Component: KlimavollautomatH13 0150
   Revision: 121609      Serial number: 8P0820043D
   VCID: 2D5B7810CD81
Address 09: Cent. Elect.        Labels: 8P0-907-279-23-H.lbl
   Part No SW: 8P0 907 279 C    HW: 8P0 907 279 C
   Component: Bordnetz-SG     H34 0301
   Revision: 00H34000    Serial number: 00000001241368
   Coding: A1884F06A214100000000000000000000000FE0F5C
   Shop #: WSC 06314 000 08192
   VCID: 3D7B48501DE1
   Part No: 8P2 955 119 B
   Component: Wischer AU350   H01 0130
   Coding: 00062736
   Shop #: WSC 06314
1 Fault Found:
00526 - Brake Light Switch-F
            008 - Implausible Signal - Intermittent
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 D    HW: 8P0 959 655 D
   Component: Airbag 8.4ED    H00 0140
   Coding: 0011603
   VCID: 438F3EA87B05
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 021 0050
   Coding: 0000012
   VCID: 356B507025D1
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 981 A    HW: 8P0 920 981 A
   Component: KOMBIINSTR. VDO H73 0300
   Revision: D04         Serial number: 224NDD04002242
   Coding: 0004413
   Shop #: WSC 00533 067 57207
   VCID: 3669577C38D7
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 D    HW: 1K0 907 951
   Component: Gateway         H08 0100
   Revision: 08          Serial number: 2500104B07082D
   Coding: 3D0F0B42070101
   VCID: 28558904E263
1 Fault Found:
01304 - Radio
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 163
                    Mileage: 187857 km
                    Time Indication: 0
                    Date: 2012.06.11
                    Time: 14:58:48
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Revision: D04         Serial number: AUX7Z0DNFNB08C
   Shop #: WSC 00000 000 00000
   VCID: 3669577C38D7
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN1.lbl
   Part No: 8P0 959 801 E
   Component: Tuersteuerger.  H10 0030
   Coding: 0000048
   VCID: 3D7B48501DE1
1 Fault Found:
00932 - Electric Window Motor; Drivers Side (V147)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.8       1502
   VCID: 31636460D1B9
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 C
   Component:    KSG          H04 0050
   Coding: 008000186D288505489AC63000
   VCID: 3C7D455406FB
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H02 1301
   Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Part No: 8P0 951 177
   Component: Innenraumueberw.H03 0020
Address 47: Sound System        Labels: 8Px-035-382.lbl
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH25 0160
   Revision: 00003       Serial number: 10000001178012
   VCID: F0E521649A33
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MIN1.lbl
   Part No: 8P0 959 802 E
   Coding: 0000048
   VCID: 3E794F5C10E7
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D5B7810CD81
End   ---------------------------------------------------------------------
All I can say is, if its showing a fault, then obviously somethings had a problem or has a problem, sorry I don't support counterfeit users.
OK, fair enough, thanks.
I'll get it to a garage or find someone with an official cable, N8 couldn't do it until the end of the month for me and I think I need to get it sorted before then.
Got it sorted at the garage today, the juddering was coming from both rear tyres being out of shape.
Glow plug fault cleared, will be taking it back if ti comes on again.
