Flashing brake light in DIS after xenon install..help
technics100 Oct 4, 2009
  1. technics100
    technics100 Active Member
    850
    25
    I installed at 4300k HID kit yesterday that I got from eBay, all in and working but when I put the xenons on the Word "brake" flashes on the DIS and the ESP light stays on. I scanned the car last night with vag-com and it found errors in the abs module, convenience module etc. I will post the exact codes later when I'm at the computer. I ended up taking them back out and putting standard bulbs back in, the car was fine with no vag-com errors. Any ideas how to fix this or are the HIDS just not compatiable with the Audi?
    I'm annoyed as it looked the ticket..
  2. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    I believe this to be a switch on HT spike problem from the ballasts, which is being picked up by the "crash" sensor cables. The sensors are mounted on the front of the car. After re-instating my headlights after a front strip down, this was happening all the time when I switched my aftermarket Xenon's on.
    I traced the crash sensor wire and rerouted it away from the headlights as best I could - this has reduced the error significantly at Xenon switch on from near 100% to ~5% of the time. In fact I can't replicate it at the moment!
    Just to add this is my second set of Xenon's, had the "fat" ones, now have the "slimlines" fitted in the headlight unit.
    It' can be annoying but to clear this fault. Switch off the ignition and remove the key - reinsert the key restart the car - should clear. Of course will remian in DTC as "miscommunication error".
    Interesting, that I did inspect the crash sensor wires the other day and found them to be screened, so maybe this cable is susceptible to interference.
    Need to do some more investigation. Any one have any experience of this too?
  3. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    Technics - Did you get the same kit as Marc1's, There was a link posted up somewhere to the slimline kit , think it was around £55 delivered! I just wanted to make sure before I buy :eyebrows:
  4. technics100
    850
    25
  5. technics100
    850
    25
    Woorlord, thanks for that. Do you know where the wiring for the crash sensors run? I have mounted the ballasts underneath the headlights, where did you mount yours? Is it worth remounting them away from the front of the car as much as I can? Here are some pics of mine.. they came with side lights too..
    Before
    After
    Wiring
    Ballast
    Sidelights
    Dipped Beams
    I will move the ballasts and see if that makes any difference, also sorry for pic quality.. it's an iphone!!
  6. technics100
    850
    25
  7. technics100
    850
    25
    I moved the ballasts away from under the headlights closer to the rear of the engine bay and it seems to be fine, no errors.. Happy days..
