FL headlight removal
Chriscooke May 1, 2013
  1. Chriscooke
    Chriscooke Clueless!
    498
    23
    Does anyone have a guide on how to remove the headlights on my QTS (facelift)?
    Cheers.
  2. Oranoco
    Oranoco Well-Known Member
    3,816
    355
    Open bonnet, unplug headlamp loom and indicator, plug, undo 3 torx bolts, 2 on top and one burried down the back of the headlamp in line with the indicator headlamp join (as it would be if they were pre facelift lights). Slide the lamp outwards to the side to get it off the lug and withdraw.
  3. Sulli79
    Sulli79 Active Member
    541
    37
    image.jpg There are the two bolts at the top one at the bottom to the side and this bracket at the bottom corner nearest the radiator should pop out, failing that you will need to drop the bumper
  4. Chriscooke
    498
    23
    Sounds simple enough. Cheers guys :)
  5. Chriscooke
    498
    23
    Headlights out, cheers for the advice. Ive now come to a stumbling block while fitting my hids in that I have no idea where to plug them in.
    This is what I have
    Red plug is the hid ballast. Do I simply wire the standard headlight feed in to the ballast or am I missing the point completely?
    If these two plugs do get connected I guess I simply remove the original plug and connect it? Is it important which way round the wires go?
  6. aragorn
    18,019
    714
  7. Chriscooke
    498
    23
    I got it from the group buy on here, was hoping for it to be plug and play but alas not. Does it matter which way around the wires go? Assume it does.
  8. aragorn
    18,019
    714
    Well get onto the group buy folks and find out why they've not supplied that connector!
  9. Chriscooke
    498
    23
    Fair point, will do :)
  10. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Take a look at the rest of kit.
    You should have everything there you need.
  11. ScottD3
    15,161
    1,121
    This is what was in my pack.
  12. steady jay
    steady jay Member
    184
    Got mine from the group buy had it fitted in an hour just plug and play. Although I didn't get a keyboard with my kit......
  13. ScottD3
    15,161
    1,121
    I only got the lower section of the keyboard.
  14. steady jay
    steady jay Member
    184
    Watch a few episodes of count down and you'll never need the other half :)
    ScottD3 likes this.
  15. Bradderz_1988
    3,945
    235
    You basically plug the two spade connectors of the hid bulb in the h7 headlamp connector then all the other connectors will match up to them of the ballast as above really post a picture of your kit and lets have a see what you have.
  16. Chriscooke
    498
    23
    It appears I was sleep deprived yesterday. Had a look today and had the lot fitted in a little over an hour. Good kit, useless DIY mechanic :D
    ScottD3 likes this.
