FK Halos
Speedy Jul 25, 2007
  1. Speedy
    Speedy Member
    85
    Just bought a set of the black FK Halo headlights, got them fitted but the level adjusters no longer work. Am I missing something, there are no instructions to speak of? Other than that they are quality...
  2. Randomjim
    Randomjim Active Member
    2,752
    You need to take the unit off your old headlights. I didn't bother with mine.
  3. Speedy
    Speedy Member
    85
    Is that easy?
  4. turboaudi
    turboaudi Member
    58
    piece of cake mate. i did them with mine ,you just twist and pull out the false ones on the new units and fit the others just make sure you get them the right way so they go up or down
  5. billybravo
    billybravo Active Member
    1,045
    can i ask where you got these from and how much cheers :)
  6. Baker21
    Baker21 OEM+ A4 Avant
    79
    Probably a little late but you will need to remove the 'fixed pivot' off the FK units and replace it with the 'levelling motor' from your OEM headlamps.
    This is common on any aftermarket headlamps that you purchase.
  7. Speedy
    Speedy Member
    85
    I will have to remove the FK's again anyway so this isn't a problem, I basically didn't look at the old ones to know the motor was inside the oem lamps, I assumed it was outside the unit - you know what the say about assumption!! One of them is faulty anyhow so they have to come out again - the right side light reflector points at the ground as it's not attached to one of the beam adjusters.... Got them off EBay by the way, there are a few on there.
