Fixing Grille Badge
a900ss Mar 2, 2004
  1. a900ss
    a900ss New Member
    Can you please help. I have finally got around to getting a 'Quattro' grille badge and am a little unsure of how to fix it. It has two plastic lugs coming out of its back and on each lug is a metal clamp. Both of these metal clapms are very loose. Do I just push each lug into the grille with the metal clamps on or do I remove the metal clamps, push the plastic lugs through the grille then push the metal clamps onto the lugs from inside the bonnet.
    Many thanks for your help and I know it seems a silly question.
    a900ss
  2. AndyMac
    9,832
    45
    The latter i.e. remove the metal clamps, push the plastic lugs through the grille then push the metal clamps onto the lugs from inside the bonnet
  3. raywph
    raywph New Member
    15
    Could you let me know where you got your quattro grille badge? I'm awaiting the arrival of my new A4 sport. Would the badge you have fit the sport grille?
    Cheers,
    Ray.
  4. a900ss
    a900ss New Member
    try searching for "VAG Parts" on google.
    Don't know if it will fit sport grille but the guys at VAG parts should be able to help.
    a900ss
