Fixing a brake light?
Johnnyb Jan 17, 2008
  1. Johnnyb
    Johnnyb Well-Known Member
    734
    301
    Hi,
    Does anyone know how to fix a brake light on an 07 S3? got the warning indicator today, is it just a case of changing the bulb? or would the dealers need to take it in?
  2. h5djr
    9,311
    1,689
    Here is a link to the workshop manual page on how to remove the rear lights on a 3-door A3 - looks quite straight forward.
    Remove rear lights - 3 door
  3. Johnnyb
    734
    301
    Thanks for that mate, very helpful:)
  4. Johnnyb
    734
    301
    Just one last thing.....
    Will the DIS display automatically clear the warning message? or do you reset that yourself??
    Thanks in advance
  5. h5djr
    9,311
    1,689
    The DIS checks the bulbs etc every couple of minutes so as soon as the bulb is changed the warning on the DIS will disappear.
  6. bacardi
    bacardi Active Member
    1,139
    be bl**dy careful taking the rear light assembly out, managed to break one of the lugs on mine when I first changed the brake light bulb!!
  7. h5djr
    9,311
    1,689
    It's funny but with all 6th of my A3s, I've only had to change a headlamp bulb. Perhaps that's a bit dangerous!. I'll probably go out and get in the car tomorrow and the DIS will go mad and tell me all the bulbs have gone!!!
  8. Johnnyb
    734
    301
    Thanks for that,
    Im really busy at work the next few weeks, if i cant do it myself do you think the dealer could change it while im waiting? how long does it take?
  9. h5djr
    9,311
    1,689
    I think it should only take a few minutes. I find that if give them a ring first and get them to suggest a convenient time they are usually quite happy to oblige and do it while I wait.
  10. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    I believe they will charge you 0.1 of an hour's (i.e. 6 minutes) labour to change the bulb.
    Most garages do this.
    Although they may be helpful and do it FOC.
  11. Johnnyb
    734
    301
    Thanks im gonna give them a call tomorrow and see if they can do it FOC
  12. a3guy
    a3guy Member
    206
    it is so simple it is hardly worth going just 1 screw , done this twice now.
  13. MarcQuinlivan
    2,539
    I agree, I've done it two or three times too - all on the driver's side for some reason - and it takes two minutes.
