Fitting Xenon Headlights **** HELP
otterolly Dec 20, 2010
  1. otterolly
    otterolly New Member
    17
    Hi
    does anybody know of anyone that retrofits xenon headlights around the newcastle area ??
    thanks
  2. unikarl
    unikarl Member
    367
    I know that hazzydays will come to you but it costs you for it!
  3. Wrath
    Wrath Well-Known Member
    1,196
    42
    From what I've read it is a pain, mainly due to the fact that you need to have headlight washers with xenon lights. I have no idea why.
  4. Sam W
    Sam W Member
    175
    EU regs is why, along with automatic headlight adjustment and leveling.
  5. hades-
    9,481
    646
    fit them yourself very easy
    iv never once been refused a MOT for haveing them fitted
  6. aragorn
    18,490
    855
    Thats a bit like saying "i've never been refused an MOT on my car with a hole in the floor, a loose steering wheel, and razor blades glued onto the wings"
    Just because you may have passed an MOT, doesnt make it any more legal.
    HID's need auto levelling, washers and the burners need to be fitted to type approved light units.
    This means you can retrofit, but only using a type approved headlight (ie an OEM Audi HID headlamp unit) and with the appropriate levelling and washing systems.
    A HID bulb fitted inside a H7 Halogen projector headlamp doesnt meet the regs, even with the other parts added.
  7. hades-
    9,481
    646
    well i never said it wasnt legal
    i said iv never had a problem or anyone i know has had a problem with a mot
  8. Sam W
    Sam W Member
    175
    It's not about passing the MOT, it's about being legal, and considering other road users. There's nothing worse than someone with HID's fitted into reflector headlamps, it's almost as bad as someone whose beams aren't adjusted properly, the law is there for a reason.
  9. NHN
    29,417
    1,740
    Do you have these lights already or looking for a complete solution, do you mean oem headlights or aftermarket xenons?
  10. unikarl
    unikarl Member
    367
    What I don't understand is why the people that make xenon headlights dont make the arc ti be in the same position as where the filament in a bulb would be. Its not about how bright they are as you can put 100 watt bulbs in your headlights and they will still give you the same beam pattern.
    I have a HID kit fitted to my standard headlights and I've adjusted the position of the HID arc to be exactly where the original bulbs filament was and I do now have a perfect beam pattern from them with no unwanted flare at all.
  11. otterolly
    17
    I already have the headlights etc., they are oem. I also have the headlamp wash system incorporated into my car, this was fitted from new.
    NHN.......do you know of anyone around Newcastle area that would do retrofits ?
    thanks
  12. NHN
    29,417
    1,740
    Ye me, if you pay me enough lol, serious note, yes I do these jobs for people, PM me to discuss further.
