Fitting trip wiper stalk question
Stu-pid May 29, 2013
  1. Stu-pid
    Stu-pid Member
    84
    Just a quick question I have just got the a4 with cruise already fitted but no trip on the wiper stalk can I just buy a new stalk and plug and play or do I need to change a module ?
  2. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    No need to change module but it will need coding
  3. Stu-pid
    Stu-pid Member
    84
    With vcds? Can you get it for windows 8
  4. Audi Doodah
    Audi Doodah Active Member
    377
    35
  5. Stu-pid
    Stu-pid Member
    84
    Which kit do I want vcds lite?
  6. Stu-pid
    Stu-pid Member
    84
  7. Stu-pid
    Stu-pid Member
    84
    Is there a specific part number I should be looking for ?
  8. archemist
    archemist Active Member Team Vegas Yellow VCDS Map User Audi S1
    256
    If you mean for VCDS try Nigel - NHN on here as he is a registered supplier for the genuine kit. Or check the map to see if a user is local to you.
    The coding involves setting the DIS options and needs VCDS or dealer input but as above if your cruise works then the SCCM should be already mid or highline (Cruise Control Retrofitting (8E) - Ross-Tech Wiki)
    part numbers for DIS stalk for a saloon are (you need one of these!!!):
    [TABLE]
    [TR]
    [TD="bgcolor: #D7DBD3"][TABLE]
    [TR]
    [TD="align: center"](1)[/TD]
    [TD]8E0953503B[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"][/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"]switch for wipers/wash-wipe operation / for models with onboard computer
    / sedan [TABLE]
    [TR]
    [TD="align: center"][/TD]
    [TD]8E0953503B 4PK[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #D7DBD3"]soul (black)
    / [TABLE]
    [TR]
    [TD]4E0953503B[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [/TR]
    [TR]
    [TD="bgcolor: #E1E1E1"]switch for wipers wash/wipe operation and on-board computer
    / sedan [TABLE]
    [TR]
    [TD]4E0953503B 4PK[/TD]
    [/TR]
    [/TABLE]
    [/TD]
    [TD][/TD]
    [/TR]
    [TR]
    /[/TD]
    [/TR]
    [/TABLE]
    there may be others but 4e or 8e 503b in black should be ok.
    I did a small write up for dis / cruise which links to others:
    http://www.audi-sport.net/vb/a4-a4-cabriolet-s4-forum-b6-chassis/177459-dis-cruise-done.html
    and there's some stuff in the sticky's
    cheers
    And
  9. Stu-pid
    Stu-pid Member
    84
    Thanks for the info most appreciated
  10. Stu-pid
    Stu-pid Member
    84
    Got one ordered
  11. Stu-pid
    Stu-pid Member
    84
    So I've fitted my stalk but need to get it coded on vag com. Anybody local to Doncaster fancy helping me out
  12. stu_m
    1,441
    I'm in hull if you want to take a drive?
  13. Stu-pid
    Stu-pid Member
    84
    Yeah don't mind that only a trip down the m62
  14. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    im junction 36 m1 at birdwell barnsley if it helps
  15. archemist
    256
    i'm near gainsborough
  16. Stu-pid
    Stu-pid Member
    84
    Cheers guys when is good for you?
  17. stu_m
    1,441
    stu-pid I know we have already started to sort something out but if any of these guys are closer for you don't feel obliged to come to me
    go with whoever is best for you I don't mind as long as you let me know :D
    No point traveling further then you need to
  18. Stu-pid
    Stu-pid Member
    84
    Cheers mate your all about the same away. It's just whoever is available soon as. Cos it's stopped my key fob working to unlock the car.
  19. stu_m
    1,441
    as I say I can do whatever is best for you but it shouldn't have stopped the keyfob working!! have you done the old key in the ignition turn it on and press the buttons this usually syncs it back up
  20. Stu-pid
    Stu-pid Member
    84
    I will try that. Is there a certain process.
  21. stu_m
    1,441
    Not really just stick the key in turn ignition on and press lock and unlock a few times then remove and try it
  22. Stu-pid
    Stu-pid Member
    84
    That's the locking sorted. Cheers bud
    stu_m likes this.
  23. stu_m
    1,441
