Fitting the Rear Number Plate
Smeds Sep 6, 2013
  1. Smeds
    Smeds Active Member
    323
    39
    The first job whenever I buy a new car, is a set of number plates, they arrived this morning so promptly took the old ones off. Front first and new plate fitted, slightly off centre but only a few millimetres.
    On to the rear, removed the old plate to find there's a bit of a recess. I don't like having screws on the plate and always opt for the stickers, but there's not a lot of surface area so not sure what to do. I could get a couple more stickers and cover every inch of panel that meets the plate but not sure how good this will be. THe other option is to screw a mounting plate on and then fix the plate to that. Other cars have all been a nice flat surface.
    Any suggestions?
  2. A3_Mayhem
    A3_Mayhem Member
    42
    I only ever use the cushioned double-sided tape (comes on a roll), that's recommended for fixing plates... get the right spec with a hi-impact adhesive layer and you should be fine. I'm the same in terms of drilling plates - just seems so wrong.
  3. NHN
    29,594
    1,782
    As above, grab some pads from audi parts departments which are great for plates come on a strip & just build up the area where it would stick, doesn't need the whole recessed area building up, just 2-3 strips & I never drill plates or use screws, looks awful.
  4. Smeds
    Smeds Active Member
    323
    39
    Is this the stuff? I've only ever needed to use the strips that come with the plates. If it's not thick enough I guess I can just double up to bridge the gap.
    Halfords | Harris Number Plate Tape (12mmx4m)
  5. A3_Mayhem
    A3_Mayhem Member
    42
    Looks the ticket.
    One of the review comments says it's quite thin; you might need to use more than one layer to 'build-up' the lower profile areas.
  6. Smeds
    Smeds Active Member
    323
    39
    Sorted, cheers!
  7. Helifella
    Helifella Co-Driver ~ Hattie Staff Member Moderator Regional Rep VCDS Map User
    571
    154
    43
    Heavy duty Velcro either side of the indentation does the trick.
  8. DarkBunny
    DarkBunny Active Member Team Sprint Audi S3
    497
    112
    43
    Four vertical strips (double sided pad tape) equally distant and mines not budged!
  9. sliced
    sliced Drive safe, stay alive.
    1,572
    335
    I've used lots of sticky pads, number plate hasn't fallen off yet! Front ones are screwed on due to curved front.
  10. NHN
    29,594
    1,782
    If you use the right strips & positioned well, the fronts wont come of even with curve, done it like that for years, also helps to bend the plate beforehand & give it a little bit of shape :)
    sliced likes this.
  11. Smeds
    Smeds Active Member
    323
    39
    All done, got the car out and the gap isn't as big as I'd first thought. Put a strip of the tape all the way round the outside and a double strip in the middle padded out to meet the plate. If the next owner wants to change the plate he's going to have to change the bumper. That plates going nowhere.
