Fitting sidelights
panamadi Apr 13, 2010
  1. panamadi
    panamadi Strider
    96
    Does anyone have a fitting guide for the replacing of sidelights (not the DRLs).
    In the manual it says 'should only be carried out by an audi workshop'-are they taking the pee or is it a ballache??
    Thanks guys
  2. waqi
    waqi Member
    150
    would be helpful to know if you got xenons or halogen, and if its prefacelift?
    My pre-facelift halogens are in the same "hole" as the main beam bulb. You gotta remove the main beam bulb and follow the wire with your fingers, then should gently pull out. Its a very very tight fit, so helps having small hands! :icon_thumright:
  3. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    I've got big hands and managed to do it, But I have got fingers like ET :)
  4. jungleman
    jungleman Well-Known Member
    2,035
    42
    is it a case of tug or twist?
    ive got a 56 plate with xeons lol
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    tug then remove the bulb from the holder
  6. jungleman
    2,035
    42
    ah so the just clip in then gdgd
    cheers for that, gonna have a go in a bit haha :icon_thumright:
  7. jungleman
    2,035
    42
    ouch ouch ouch!!!
    how are u meant to hit your hands in there and get the sidelights out lol!! ive just cut my hands to pieces haha
    any advice guys? lol
  8. PH1L
    PH1L Gievf Buckets
    3,851
    40
    its held in by a tight fit and its even tighter to get your hands in, i think i ended up reaching behind and upside down to get in there but my hands were still all cut etc
  9. jungleman
    2,035
    42
    yea i can imagine.... hummmm where is the gf when she is needed haha
  10. a3_dan
    a3_dan Member
    588
    I had this few weeks back. I pulled firmly on the cables, not too much mind or you will break the cables/plug. I had a few cuts afterwards!
    You need jeremy beadle hands for this!
  11. robby
    robby Active Member
    579
    69
    I used a flat screwdriver to lever them out slightly then pulled by the wires
  12. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    221
    So they can charge you for the privilege i expect, ha.
