Fitting RNS-E Sat Nav
Hawesy May 29, 2012
  1. Hawesy
    Hawesy New Member
    20
    Hi guys,
    Just received my RNS-E Sat Nav, looking to fit it tonight if possible. Have rung my local Audi dealer but they said they haven't got any tools in stock to get the original stereo out and it will take 3 days to get them in. Do I need these removal keys to get it out? Or can I use the old coat hanger trick?
    Thanks in advance.
  2. kite
    kite Member VCDS Map User
    677
    Try halfords for keys...
  3. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
  4. marktdisport
    marktdisport Active Member
    1,195
    15
    halfords tools work m8 tested them myself
  5. Hawesy
    Hawesy New Member
    20
    Just been to halfords, they only had 2 so bought them. Realised I defiantly need 4 lol so can t do it anyway!!!! :mad:
  6. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    Did you get the plain metal ones or the ones with plastic coated handles?
    The RNS-E can be a very tight fit sometimes, and the plain metal ones can cut into your fingers if you're not careful.
  7. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,249
    192
    I've found you can do it with 2.
    Do one side then they'll wriggle loose. Then pull out the other side.
  8. Hawesy
    Hawesy New Member
    20
    Hi guys,
    Got another set of keys from halfords, had an absolute nightmare with them and took em straight back.
    Ended up cutting my hand, and scratching the original unit. Going to wait until the Audi keys come and do it that way. Hate being patient lol but don't want to force it out!
    Thanks all for the advice
  9. Cabbyfan
    Cabbyfan Active Member
    840
    34
    My advice would also be protect the console sides with tape or thin plastic before removing either the radio or the climate unit....the plastic marks very easily !
  10. Hawesy
    Hawesy New Member
    20
    Deffiantly thanks
  11. PetrolDave
    1,559
    85
    What I said... the Halfords ones are for masochists.
  12. Hawesy
    Hawesy New Member
    20
    Got my Sat Nav fitted at last. Loving it!
    Before
    After
  13. Speed_Demon1978
    Speed_Demon1978 New Member
    Hi mate looking at getting this done myself as replacement for the current symphony set-up with the 6CD built in. What other bits and pieces did you need and did you have to connect another CD changer too?
  14. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    Have you coded it yet so every thing works
  15. Speed_Demon1978
    No mate, haven`t actually gone about doing anything yet as want to see whether the cost/time/effort would be worth it? Currently have one of those cassette adaptor things using it with my iphone doing the job at the mo for the music :yes:
