Fitting new oil pump
Rs6mick May 6, 2013
  1. Rs6mick
    Rs6mick New Member
    27
    Hi people going to take my sump off and give it a good clean and put a new pick up pipe on with a new oil pump but my question is would you change the chain and tensioner as well I don't even know if it possible to do this with just the sump off any help would be much appreciated
    thanks
  2. Rs6mick
    Rs6mick New Member
    27
    Bump anybody
  3. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    dunno but would also like to know?
  4. <tuffty/>
    21,560
    4,044
    You need to remove the crank pulley and remove the front crank seal to gain access to the chain and tensioner... you would need a new crank bolt too... they are a complete **** to remove in the car...
  5. danger S3
    danger S3 Member
    374
    19
    changing the chain and tensioner is a massive pain, it goes up round the crank so involves a lot of dismantling, more hassle than its worth unless obviously it has a problem.
