Fitting my Brembos?
vfr800 Sep 17, 2013
  1. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    Hi chaps!
    I finally got myself a pair of LCR Brembos, they're in the classic SEAT peeled-lacquer faded-red colour.
    Got the mounting bolts, brackets, pipes, callipers, and some virtually brand new pads and discs - straight off an LCR.
    ECP have a deal on at the moment so I'm getting 1L of the ATE Blue brake fluid for £10-delivered. (I already have an eezi-bleed kit)
    Now my question - is there anything special that I need to do to stop air going back up the brake lines when I disconnect the old brakes and plumb the new ones in? Or will the eezi bleed kit push out any air that gets in in the line when disconnecting/reattaching?
    I'm contemplating getting them repainted before I fit them - I googled and found a company in Nottingham that will sort them for £115 / pair.
    Cheers, Liam
  2. <tuffty/>
    20,896
    3,705
    Bleeding will removing all the air (if done properly of course)... don't clamp the hoses as they are braided internally and it can damage them... I normally use a bit of polythene on the reservoir held on with the cap to 'seal' the reservoir and slow down the flow of fluid while I swap over the hoses... loss of fluid is inevitable but as you are bleeding fulling with new then largely irrelevant
  3. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Who are you using to do the re-paint? £115 a pair seems like good value. I'm in the process of enquiring with Godspeed to powder coat these bad boys I picked up a few weeks back:
    They want £85 per caliper to strip and powder coat...
  4. chaz20vt
    chaz20vt Member
    428
    21
    Iv got my self this pressure bleeder, Any particular way or sequence to bleed to get a nice solid pedal (standard s3 312mm brakes)
    Thanks Chaz
  5. vfr800
    773
    57
    Thanks Tuffty.
    I googled and found ... Brake Caliper Rebuild, Painting, Repair and Refurbishment Specialists
    I contacted these guys and have been quoted, £171 inc VAT. (Painting, supply and application of decals, return delivery.)
    You do get a couple of years warranty on the paint/finish which is nice.
    I also found these guys, costs more but they are defo powder coated.
    https://www.facebook.com/BrakeCaliperRefurbs
    I'm still shopping around to find out who will be best ...
    Liak
  6. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Thanks Liam, let us know who you go with.
    What colour are you going for?
    The pictures on that facebook site are giving me the horn.
  7. vfr800
    773
    57
    I've got an email from the guys in Nottingham, I'm tending towards giving them a go: "No we don't powder coat. We use the same paints as the caliper manufacturers do, our paint is designed to get harder as it gets hotter so can easily withstand the temperatures encountered during normal brake use. Powder coating is the reverse and gets softer as it gets hotter."
    Will do, I have a feeling that if I get any other colour than Brembo red I'll regret it.
    Options: Brembo Red, Black, Yellow, Dolphin Grey (to match the car and wheels).
    They're going behind these wheels. Opinions?
    Liam
  8. Lavis89
    Lavis89 Well-Known Member Regional Rep Team Sprint Audi S4 Audi A3
    1,781
    615
    I'ld go for the red, you spent the money on getting them, might aswell show them off and make people like me jealous.
  9. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
  10. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Personally the one colour I'm not going for is Red. There's no doubt Red looks good but I just fancy something different.
    I've short-listed a few colours but that information is on a need-to-know basis at this time :tapedshut:
    Lovely looking car BTW.
  11. [Dave B]
    [Dave B] Daddy
    2,027
    145
  12. s3dave
    10,110
    736
    I got them sand blasted for £20 then powder coated them myself then got the mk1 rs seal kit so about £100
  13. [Dave B]
    [Dave B] Daddy
    2,027
    145
    That is cheap considering you've got new seals as well....how hard was it to change the seals? I've viewed some guides on-line and the only part that looks challenging is getting the pistons out (as I don't have a compressor)...
  14. superkarl
    superkarl MAN OF STEEL
    9,404
    2,378
    I vote bright silver on that dolphin grey car.
  15. s3dave
    10,110
    736
    I used a compressor, but a bike pump would do the same if you get a good seal..be careful because they can fly out with a fair bit of force, i used wood blocks to limit the travel..
    seals are fiddly but straight forward...
  16. jojo
    28,846
    3,509
    Yellow.
  17. vfr800
    773
    57
    Thanks dude!
    I'm liking your thinking there ...
    There's always one ... Red seems to be winning the vote so far, but the bright silver could be a winner too.
  18. russwuss
    russwuss Active Member
    549
    106
    43
    Vfr800, if you don't mind me asking.. Where is ATe blue brake fluid on ECP website? I've tried no end of times and can never find it... Going tomorrow for the S2000 filter so may pick up some brake fluid to :)
    EDIT: never mind I've found it, when I put my S3 reg in a search for ATE fluid I get no results... When searching with the S2000 car it found it straight away......
  19. vfr800
    773
    57
    I searched for ate blue on the ECP website. Doesn't seem to work now and the price has gone up.
    ATE Super R Blue Dot 4 Brake Fluid - 1 Litre
    Liam
  20. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    I realy need to paint mine. they work fine so new seals and things would be over kill at the moment.
    Im going red just to refresh them... although i did look at blue to match the car too.
    Im looking at spray them red. aply the brembo sticker and then 2 pak lacquer over the top
    All in will cost me about £30
  21. s3mad_dude
    s3mad_dude Noggies ruuuule!
    602
    79
    Plus 1 for yellow on a Dolphin Grey S3
  22. russwuss
    549
    106
    43
    Thanks!
    Oh btw, enter MOT25 coupon at the checkout - works out at £11.02 a Litre :) going to pick some up in a minute.
