fitting my billy b8s this weekend...right choice?
chazza55 Oct 11, 2011
  1. chazza55
    chazza55 got an S3 8L: living the dream
    173
    as the title says i am fitting my b8s this weekend and i already have the eibach pro kit springs fitted.
    Now it is generally believed on ASN that this combination is really good. (or so i understand)
    The eibach springs give a lowering of i think 20mm and 25mm. I have just been reading the Bilstein website and they say that the B8s work best in a 30-40 lowered vehicle and the the B6 shocks (the longer ones) are ok to a 30mm drop.
    This would suggest the eibach springs would be better paired with the B6 shocks not the B8.
    Can anyone comment or have experience of both B6 and B8 shocks?
    thanks
  2. JS1500
    JS1500 Howdy
    1,166
    10
    IMO the B8s are superb and you'll most likely think so too.
  3. chazza55
    173
    just the answer (and reassurance) i was after.......THANKS! :D
  4. sportquattro
    sportquattro Active Member
    834
    51
    Fitted mine a few weeks ago and love them to bits, awesome improvement
  5. Ginge
    Ginge It's never fast enough !
    192
    Same as above, had mine on just over a month and the difference is incredible combined with h&r springs. The confidence I have through the bends has increased no end :)
  6. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Weitec kicked in yo' :moa:
  7. jojo
    jojo Looking for Boost! Staff Member Moderator Team Daytona quattro Audi S3 Audi A6 Audi Avant Owner Group
    28,826
    3,479
  8. IGI
    IGI Member
    85
    Yep best investment for the S3 had mine on for over a year now ....running eibach springs too...get the r32 arbs and you'll be sorted :yes:
    Handling is spot on without being harsh or bouncy:rockwoot:
  9. fingermouse
    fingermouse thats me
    3,975
    110
    B8`s & H&R`s here, feels like it should have out of the box imo
  10. Mr.G
    Mr.G Well-Known Member Team Sepang Audi S3
    1,434
    228
    Tried and tested setup, proven to be one of, if not the best, setups on the 8L S3. I went a stage further and had neuspeed ARBs 22mm front 19mm rear, with poly bushes and rear tie arms which enabled me to run Glens custom geometry figures. I can honestly say that I am still impressed with what the car can do, even after a year!
    My issue now is that the tie arms have worked loose, the welds near the wheel side of the arm have broken off and my MOT man says it's dangerous to drive. Going to weld them up tonight and contact the supplier.
    Hassle i could do without to be honest.
    G
  11. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Where'd you get your tie arms from?
  12. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Where are these custom geometry specs...?
    And whos tie bars have you got?
  13. chazza55
    173
    are adjustable tie bars really necessary? i read that the eibach pro kit didnt lower it sufficiently for adjustable tie bars to be needed to correct the camber. i have been running stock dampers and stock shocks with stock tie bars for the past year!
  14. sportquattro
    834
    51
    With the Eibach Bilstein B8 kit mine needs the adjustable tie arms for the rear which I'll be ordering from that jolly nice S3Dave chap on here very shortly. Im curious as to how the S3's with the OEM gmbh suspension fitted fare with standard tie arms or did audi do a different tie arm for them that we dont know about? Any A-S.N members know the answer?
  15. chazza55
    173
    When you say "needs", do you mean the components won't fit together without an adjusted tie bar? Or just that it will give a rubbish geometry?
  16. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,244
    350
    the geometry needs it. It'll all still fit without them. I needed the tie bars with the HnR springs which are only a 25mm drop
  17. chazza55
    173
    bug*er.......so am i better off waiting to fit the b8s until i have the tie bars?.......can anyone recommend a set? Thanks
  18. chazza55
    173
    and does that mean that fitting the b8s lower the car further than just fitting the eibach springs?.....cos i have been running eibach springs on standard shocks for a year now without adjustable tie bars
  19. Alex C
    3,244
    350
    you can get away with no tie bars for a while i think. I think its hit a miss what sort of camber you end up with after you lower it. If it was me and i definitely couldn't get both the tie bars and shocks at the same time i would get the shocks just to keep me happy for a little while until i got the tie bars.
    I would get tie bars from S3Dave who is a member on here, you'll see him about;
    This is his thread showing you how to fit the tie bars. PM him for details; http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/94463-rear-tie-arm-replacement-too-adjustable-camber-arms-how.html
    These are the tie bars that i have on mine and when i got them fitted the mechanic was more interested in the tie bars than the billy b8s, HnRs or the roll bars! They are really well made.
    The shocks don't affect the ride height at all
  20. chazza55
    173
    ok cool.....this may explain why my rear tyres were wearing more than my fronts over the last year and slightly unevenly.......still got 8k miles out of them before they needed replacing.
    is the handling better with adjustable tie arms (correct camber) or does the -ve camber actually help for grip in the corners (grip more normal to road surface than in shear).
  21. Ian W
    Ian W Active Member
    1,058
    12
    I had the B8 / HR combo on my old S3, stupidly sold them when I was selling the car :keule:
    Hoping to get them again next year.
  22. Alex C
    3,244
    350
    negative camber helps in the corners, but i think it is preferential to have more negative camber on the front than the rear. So you want to be able to adjust the rear. Also if the cambers way off then the car doesnt handle great in a straight line. It'll also give you uneven tyre wear, you'll wear the insides out quicker
  23. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    The only after-market tie arm that ive heard of failing is KWs (quite a few) and the standard one when the rose joint seizes...so it will be interesting to see what manufacturer MR .Gs was...
  24. s3dave
    10,110
    736
    The GMBH kit was only 10mm drop IIRC....so probably within limits?
  25. superkarl
    superkarl MAN OF STEEL
    9,329
    2,334
    i have 2.4 degree camber on the back of mine with standard shocks and springs. so i bought daves tie bars to adjust it as 2.4 degrees is just silly on a road car. perfect for the track, as in a corner more of the tire will be in contact, but on our bumpy roads you'l find the back end stepping left to right over bumps, not to mention tire wear on the inside.
    each car is different however, and everyone has different ideas as to whats acceptible, so fit your shocks and springs and see how it looks
    this is mine with what i see to be too much neg camber:
    and from the wear on the tires, its only the very inner row of tread thats in contact.
  26. chazza55
    173
    looks familiar and now it is being mentioned i think i have also seen my tires wearing unevenly a little last year.........gonna start saving the pennies for Dave's shiny gadget! :D
  27. Mr.G
    1,434
    228
    Hello all!
    I will refrain from stating who supplies/manufactures them. It's hardly ethical of me to slate a product and invoke bad feeling when it's completely unnecessary. Besides the company have been nothing but great with anything that I've had queries on.
    What I will say though is that the Mechanic who looked at the car (failed it's MOT because of these) was shocked at the poor quality of the item. Stainless steel arms and brackets but the bolts where not of stainless steel quality so corroded and rusted, allowing the bracket to pull away from the arm. I was told that I was not allowed to take it away from the garage (test centre) in its current state as it was very dangerous.
    I had the bracket welded to the arm so that I may drive it to the supplier. I'm hoping they will oblige kindly (as it's been a headache and worry)to resolve the issue and to change them, as it's an inconvenience and I have a fair way to drive that's all, which is another worry.
    The custom geometry on the car is as per Glens setup, Ess_three, tried, tested and according to glen proven best setup on his S3, despite multiple components being used, i.e Eibach, coilovers. The B8 and H&R setup speak for themselves, you can tell a good setup instantly and it was like this for me when I jumped in the car after it was all done. I love the way it drives.
    I can forward the Geo setup/figures for anyone who wants it. Just PM me, trust me it's worth it for those who have adjustable tie arms. I debated for about 2 months before handing over around 5.5K (had other things done too) for the work to be carried out.
    G
    P.s Pictures to follow of the cars stance when properly setup
  28. chazza55
    173
    I think I will be getting a adjustable tie bar off Dave (if he is willing), but if i were wanting a cheaper route than adjustable tie arms, are shims or eccentric bushes any good?:
    SuperPro Uprated Suspension Bushes, Audi S3 8L, 1.8 Turbo APY, AMK, BAM engine codes (1997 - 2003) Rear track control arm upper or lower inner bush kit with camber correction (2 kits required per car!) just have visions of the eccentric insert rotating and changing the camber as you go round a corner!
    are shims available for the s3?
  29. Alex C
    3,244
    350
    It’s not hard to dig around for the answer to find who it was.
    IMO given that the state the item was "very dangerous" it would probably be a good idea to share what product it is you are talking about so others with the same product are aware of the issue you talk of?
  30. Alex C
    3,244
    350
    they're not adjustable though
  31. Mr.G
    1,434
    228
    Excuse the dirty sl4g, I live on a building site (new home), so when it's wet, car = dirty!
    As you can see slight camber on the rear wheels, not loads but enough for a nice bit of grip.
    4 X New tyres (very very good I must say, so glad I got them, had the normal asymmetrics before fitting these).
    Some others that I though't i'd share.
    After I performed a GTechniq Detail using full product range (inc C1)
    G
  32. Mr.G
    1,434
    228
    Thanks for pointing that out lol...as if I didn't already know. I specifically said I wasn't about to publicly name and shame a company without letting them investigate and at least reply to my e-mail first. Fair is fair...is it not?
    We all know what product we are taking about as I've already said
    If others have purchased tie arms for the S3 then I personally would be checking them for signs of wear, faults. You'd know if you had a failure. I'll be keeping an eye on mine after this scare, even when new ones are fitted, i'll be doing my checks.
    G
  33. Westy
    Westy Well-Known Member
    17,440
    1,097
    Hi G, long time. Have you been in contact with the supplier? I know where you got them from and I'm sure that company would like to know. They may also offer you another set or some form of compensation, maybe.
  34. Alex C
    3,244
    350
    thats fair enough, but personally i would want to know:salute:
  35. Mr.G
    1,434
    228
    Hiya Wes!
    Yea long time mate. Have been in contact and am awaiting a call! Hopefully it'll be good news.
    G
  36. DPM
    DPM Site Sponsor Site Sponsor
    4,917
    179
    One of the best setups available for the S3 but always best and sometimes essential to fit tie bars when lowering them.
    Damian @ DPM Performance
  37. mk1chopper
    mk1chopper Missing the S3
    1,092
    The bush's are an option but for the price that dave sell's the tie bars for I'd just get them instead and have it setup correctly.
  38. Mr.G
    1,434
    228
    Update:
    After speaking with Awesome GTI about the faulty tie arms I arranged for them to be replaced. As they were out of warranty period there was little Awesome could do in terms of replacements. However, what Awesome offered was to discount a new pair for me and offer to fit them free of charge. They also carried out my custom geometry setup for free as a good will gesture. I was happy with this and could understand the position they were in. Although it did worry me that such an essential component on the car was in such a poor shape just over 1 year on, not Awesome's fault as to me it is a manufacturing defect in the supplied part.
    So car is now back with me in tip top, I have had poly bushes fitted on the rear now which means the whole car has them throughout. It does feel a whole load better than it did, which I didn't think was possible given the time and money i've invested in getting it to a good standard, it just goes to show that bushes make a huge difference to how a car feels and performs.
    I want to give a shout out to John, Al and Hassan of Awesome as they looked after me and the car for the fourth visit.
    G
  39. Westy
    17,440
    1,097
    But is someone going to be reviewing the product? You could end up in the same situation in another years time.
  40. colicabcadam
    colicabcadam Guest
    sorry, but 1 year warrenty on an important mechanical part, are you having a laugh?
    it's clearly not safe and clearly not fit for purpose, you should not have to pay a penny to have the issue fixed, it's life threatening, not just to the occupants of the car, but to other road users too
    if i were you i'd have a ccj on the suppliers arse straight away
    you believe they've done you a favour - they have not, they've charged you to correct and replace a poorly constructed item that they sold to you in the first place !!!
