Fitting my 710N
voteforpedro Apr 7, 2010
  1. voteforpedro
    voteforpedro Member
    632
    So I managed to snap the thin hose that goes to the intake manifold. :(
    Now the revs are dipping like crazy when idling, before eventually settling. Is running with this hose open and not connected to anything likely to be the cause?
  2. Oranoco
    Oranoco Well-Known Member
    3,913
    392
    The vcume pipe to the top of the DV? Yes mate. You need to get this sorted.
  3. voteforpedro
    voteforpedro Member
    632
    Can I just block it off for now?
  4. Oranoco
    3,913
    392
    Not ideal the car will be down on power and fueling will be on teh piss as the DV won't operate correctly.
  5. voteforpedro
    voteforpedro Member
    632
    Where can I pick some up from off the shelf?
  6. Oranoco
    3,913
    392
    I just popped some silicone hose in when I did mine. Think you can even get the stuff in Halfrauds these days
  7. aragorn
    18,300
    805
    At the very least you need to block the pipe up at the manifold end, which will stop the air leak thats causing the crazyrevs.
    Dont drive it hard either as the dumpvalve is basically disabled, and may leak.
    You can get suitable vac hose from ebay.
  8. voteforpedro
    voteforpedro Member
    632
    Any ideas what diameter it is?
  9. Broken Byzan
    13,237
    465
  10. voteforpedro
    voteforpedro Member
    632
    Cheers fellas.
