Fitting lowering springs at home
1inchpunch Sep 16, 2011
  1. 1inchpunch
    1inchpunch Member
    451
    As the title says. I'm thinking about fitting lowering springs and as I've never done it before I was wondering if it's a home job or not. I've got most of the tools needed and am a fairly competent mechanical DIYer but have never done this job before, brakes is probably the closest I've got. I'd just like to save myself the £200 it would cost to have it done somewhere.
    Also interested if anyone has a DIY for this. Done a search on here and Google and can't find anything.
  2. chris-edin
    chris-edin Member
    116
    I've fitted springs / coilovers myself, easy enough if you have spring clamps. Impact driver is handy too.
    Only thing you'll need to get after is 4 wheel laser alignment :)
    Chris
  3. Lewis583
    956
    91
    I can sort out a pdf of ELSA removal instructions if you wish mate?
    Also as above, Spring compressors are a necessity for removal
  4. 1inchpunch
    1inchpunch Member
    451
    Cheers for the replies guys. Knew I would need spring compressors but thankfully they are pretty cheap. Another thread from today also mentions some kind of socket that's needed but again it still keeps me well shy of the £200 fitting cost.
    Lewis, PDF would be a big help if you've got it.
  5. Lewis583
    956
    91
  6. nally
    nally MPG the new BPH
    2,104
    34
    is it dangerious using those spring compressers
  7. pinterovski
    pinterovski Member
    667
    88
    Mate,£200 for fitting springs????????
    Explain please,because that's alot of money:scared2:
  8. 1inchpunch
    1inchpunch Member
    451
    Was just a ball park figure based on someone that I know that had it done recently. They paid £190 for fitting and alignment on a 335d. Maybe they were charged a special BMW tax :)
  9. pinterovski
    pinterovski Member
    667
    88
    Come to SLO mate,Alligment and fitting the springs for only £70:haha:
  10. bluequattro
    bluequattro Member
    411
    I didnt have to disconnect half as much as that how to
    M8, now i know why garages qoute £200 lol
    I dropped my a3 onto h&rs recently, my method was
    Remove front wheels
    Place car on jacks
    Disconnect front droplink from strut
    Loosen and remove bottom strut bolt
    Insert hub spreader or cold chisel to open hub gap
    Turn steering to opposite lock
    Put a bit of your weight onto the hub, it will move down
    Releasing the strut from the hub
    Once the bottom of the struts free, theres 3 small bolts at
    The top of the strut, there underneath the windscreen
    Cowling, the bolts can be removed without removing
    The cowling, once these bolts are out you can do your
    Spring change etc, i bought a cheap 12v impact gun for removing
    The strut tops, so much easier than trying to remove the
    Tops with a spanner and allen key.
    The rears are even easier to change, place car up on axle
    Stands and simply remove the bottom spring carrier bolt
    This allows the spring to be removed without spring compressors
    Etc, then do replacement parts in reverse order, i forgot
    To mention if you have hids you need to disconnect the
    Small linkages front and rear, sorry theres not more detail
    M8, im typing this on my iphone, hth
    Cal
  11. Lewis583
    956
    91
    ^^ +1
    That's the way we do it at work, ELSA takes the long winded approach.
  12. 1inchpunch
    1inchpunch Member
    451
    That's good info bluequattro, much appreciated. Why did you turn the wheel to opposite lock? Was it for access?
    Pinterovski, if SLO is anywhere near Glasgow then i'll save myself some work.
  13. pinterovski
    pinterovski Member
    667
    88
    Naahhh Mate,SLO stands for Slovenia which is far far away from you!
  14. 1inchpunch
    1inchpunch Member
    451
    Haha! Think the travel expenses might cost more than springs and fitting.
  15. bluequattro
    bluequattro Member
    411
    it changes the angle of the hub m8, and it gives a bit more clearance ;) hth
  16. Ads
    Ads License to drive
    8,230
    612
    I'd pay the £200 mate.
    Down here alignment can be £80-£90 alone, so that's leaves about £120 for the actual fitting part.
    It's good to save money, but for something that plays such a massive part in how your car drives and its safety I'd rather pay the "experts" to do it, rather than trying it myself for the first time using a 'how to guide' off the internet.
