Fitting Liquid Gauge tonight :)
Welly Aug 4, 2010
  1. finesse
    finesse Active Member
    2,805
    looks very nice Welly, I like!
  2. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Im 99% sure its standard. When I first got the car I was getting standard figures with vag com but now im getting what I mentioned above, maybe even more now as I have done some things I lasted logged .
    Nathan
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    well at least your going the right way...lol
  4. Essflee
    Essflee Well-Known Member
    2,154
    67
    Welly, your torque figure, did you get a spike at all or was it smooth, reason being when I used my mates the highest spike I got was 328lb ft and would settle at about 300 ish, I disregarded it as people say it's not achievable from a stock K04, didn't know how accurate that was as it seems a lot...
  5. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    I take it, its just sat on top of your vent ?
  6. Dani_B19
    9,380
    402
    No, it actualy replaces the vent.
  7. Dazboss
    366
    Its just on the right hand side thought i could see the vent fins, prob just me though.
  8. finesse
    2,805
    vagcom or liquid gauge
  9. s3dave
    10,110
    736
    Liquid guage is deff no substitute for vagcom its a cool "live accessory" but useless for live printable logs or people with shovel hands like me.... if you can afford it it is def worth having....for the live info on the fly
  10. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    15
    Nice one Welly! My missus bought me one a few weeks ago for our anni. It's too damn cool! :)
    I got a reading of 258bhp and 244 ft/lbs. Peak boost is read 22.3 psi. Sometimes i get 22.4 psi which is nice lol. Should be a teeny bit more but i got a boost leak under my mani! Doh!
  11. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    You sure you dont have a boost leak? My liquid gauge sees over 21psi and 290lbs running stage 1 Revo on high boost.
  12. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    If you mean me, then pretty sure, yes.
    The large port head drops the torque by producing less restriction.
  13. <tuffty/>
    21,870
    4,198
    Was leak tested prior to the dyno run to best part of 30psi with no leaks :)
  14. jimmp
    jimmp Member
    194
    sorry lads- you're going to think this is extremely daft-
    where do you get hold of a Liquid Gauge????
  15. Welly
    10,696
    130
    Page 1 of this thread - Badger5.
  16. MintyS3
    1,580
    I seee. K04 not man enough for a large port head then lol.
  17. Welly
    10,696
    130
    Not without the help of mods.
    Think of blowing through a maccers straw into the grand canyon.....
    OK, that's an exaggeration I grant you, but the size difference in ports is huge!
  18. jimmp
    jimmp Member
    194
    Another silly question-
    relative to the Race Diagnostics website for the Liquid Gauge- if I have an '01 plate car, is that "pre " or "post" facelift...?
    It's "post" right? I had a Mk1 A3 years ago...
  19. Welly
    10,696
    130
    Yeah, should be a post facelift.
  20. jimmp
    jimmp Member
    194
    thankyou-
    I e-mailed Race Diagnostics and they reckon the Liquid "might not" give oil temp on a 1.8t Quattro...
    Does anybody know if this is true...? Also, can you read and reset DTCs on the Liquid...?
  21. Welly
    10,696
    130
    Yes, you can read and reset trouble codes. My Pre Facelift S3 won't give oil temp either - but not the end of the world.
  22. mk1chopper
    mk1chopper Missing the S3
    1,092
    12
    slightly off topic, do you need the full version of vagcom to do logs, i have an ebay/3rd party cable that i've used for basic fault code finding although I cant run a full scan have I have to run scans on separate sections.
  23. Welly
    10,696
    130
    You can log blocks from 001 to 025 on shareware VAG COM.
    Useful in themselves as you can get air flows and log timing pull. Sadly boost is out of reach in blocks 118 and 115, as are fuel trims on block 032.
    I guess it depends on what you want to log.
  24. mk1chopper
    1,092
    12
    You can get an etimate of power by logging air flows right? which block is that? Whats the best way to do a log run, is it full throttle in 3rd or 4th?
  25. Welly
    10,696
    130
    4th really, but 3rd on a public road, as 4th makes over a ton at redline....
  26. badger5
    9,598
    2,060
    block 002 or 003 have g/s on them
  27. Welly
    10,696
    130
    Good spot, I missed that.
  28. Chlippo
    Chlippo Member
    679
    15
    thats nice! wellY done
    But i think they can do a better quality ones...specially that button
  29. ash3435
    ash3435 flat out if in doubt
    148
    how do you work out your torque output with vagcom.im seeing around 210g/s, sometimes more.my spikes 24psi with standard n75 valve
  30. s3dave
    10,110
    736
    divide by 0.8........ 262bhp
