Fitting LED DRL.....
Thomas_FSI May 10, 2012
  1. Thomas_FSI
    Thomas_FSI New Member
    26
    23
    Hi,
    I picked up my 58 plate Sline A3 Sportback a couple of weeks ago and it came with the bog standard DRL. I have seen some of the slightly newer A3's with the LED DRL which run along the top edge of the head lights, would it be relatively simple to swap these over if I could find a set?
    I am not too fussed about them being Xenons, if this makes any difference?
    I have had a look through the posts and can only see gash links to non OEM LED lights on fleabay
    Tom
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    post a pic of what lights you have i suspect you are prefacelift
  3. audicruiser
    audicruiser Audi Heaven
    1,865
    Can't be prefacelift as they didn't have DRL unless fitted with Xenons.
    If it is facelift (and it should be on a 58 but it is right on the change) then it is a straight swap to Xenons with LED drl in terms of actual fitment. You then have to fit washers, levellers etc...
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    he never stated if he had xenons or not, granted he said bog std but it could be a late register prefacelift
    but you cant get the led drls like mine without xenons
  5. Gweev
    Gweev Member
    74
    Am I right in thinking you only need auto levelling for bi xenons, but not for xenons?
  6. Thomas_FSI
    26
    23
    sorry it is a face lift without Xenons, do the LED only come on the xenons then?
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    Yep you will need a set of headlights ballasts adapter loom new leveller unit and level sensors
  8. mike foster
    3,967
    No you're not ! Sorry mate
  9. Gweev
    Gweev Member
    74
    Oh! :sorry:
    So, not much point in retrofitting a set off fleabay then. Explains why Audi charge nearly a grand for the option too.
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    well its worth it though
  11. Rob2k68
    Rob2k68 Well-Known Member Team Daytona VCDS Map User Audi S3 quattro DSG
    7,027
    10,616
    Maybe a white LED bulb upgrade is an option granted not as impressive as the xenon headlamp unit ?
