Fitting larger 312mm brakes
bradh Jun 13, 2013
  1. bradh
    bradh Active Member VCDS Map User
    573
    58
    Hi all I fitted these to my passat and it made a massive difference to the brakes much much better then the std set up now can I do the same to my 2003 a4 ?? Just get some larger carriers new disks and jobs a gooden?
  2. Mollygoogle
    Mollygoogle Member
    252
    9
    Certainly can, recently did the same to mine
  3. bradh
    573
    58
    Awesome off eBay hunting now ;)
  4. Paul @ Unit 9 Remaps
    Paul @ Unit 9 Remaps Site Sponsor Site Sponsor
    2,035
    132
    Yep mine has them standard just search eBay for someone breaking
  5. munchkincoupe
    munchkincoupe Member
    948
    19
    Make sure the carrier has 569 on it
  6. _adam_
    _adam_ Member
    47
    What's the parts list for this conversion as mine are ready for refreshing and I may as well upgrade at the same time
  7. bradh
    573
    58
    Calliper carriers and new larger disks that's all that's needed but Might as well drop pads in too
  8. _adam_
    _adam_ Member
    47
    What are the calliper carriers from for the 312 discs ? As in what model a4?
  9. boomtown
    boomtown Member
    130
    3.0 v6 has them as standard
    Maybe the 2.5 aswell
  10. chasdrury
    chasdrury Member
    362
    17
    ANd some late 1.8T s as well> mine is the Limited Edition and it had 312mm. now it has S4's on it.....
  11. AlexGSi2000
    AlexGSi2000 Well-Known Member VCDS Map User
    1,464
    199
    I sold my 312mm brakes for £60 on ebay - somebody got a bargain!
    I upgraded to S4 340mm brakes - if budget allows I would hunt a set down, as the difference is night and day compared to the 312mm.
  12. mixxy
    mixxy Member
    32
    I hope to have some b6 ( 2003 ) calipers and carriers coming soon that should be 312mm, is there a way of telling if i need the 25mm disc / or 28mm disc and same with pads as euro car parts lists different widths for them
