Fitting in car dvr with front and rear cameras
Patrick_c99 Jun 23, 2013
  1. Patrick_c99
    Patrick_c99 Member
    198
    Hey guys just thought I'd share a little project I'm doing at the moment.
    I'm going to be fitting this onto the underside of the parcel shelf out of site with the camera that comes with it facing out the rear :
    http://item.mobileweb.ebay.co.uk/viewitem?index=0&sbk=1&nav=SEARCH&itemId=121067861171
    And then modifying this to fit into the front grill out of sight.
    http://www.amazon.co.uk/gp/aw/d/B009ZCDXTO/ref=mp_s_a_1_12?qid=1371985535&sr=8-12&pi=SL75
    Will upload some picture once the parts arrive and give you some finished pictures as well.
  2. Mr_Freeze
    Mr_Freeze Well-Known Member
    389
    373
    Unless i'm reading this wrong, the first one is a small camera which uses a micro card in the camera to record to, so is a DVR in itself. The bigger screen part is just a Monitor and so has no recording feature.
    Therefore the is no way of recording the output from the second camera.
  3. Patrick_c99
    Patrick_c99 Member
    198
    Nope you are right. That is something I miss read. It's so hard to find a 2 channel dvr recorder for under £50 lol
  4. Mr_Freeze
    389
    373
  5. Patrick_c99
    Patrick_c99 Member
    198
    Mr_Freeze likes this.
  6. Mr_Freeze
    389
    373
    Glad I could help.
    what size drive are you going to use?
    let me know how it all works out as I will be following you lead.
  7. Patrick_c99
    Patrick_c99 Member
    198
    Was just going to stick an old 250gb Sata I have laying around in it.
    I will upload some photos once the parts have arrived and its all fitted.
  8. Patrick_c99
    Patrick_c99 Member
    198
  9. Patrick_c99
    Patrick_c99 Member
    198
    Got my dvr and just going to start making a bracket to hold it in place under the passenger seat
    And then to begin the wiring.
  10. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    220
    Looking forward to seeing the outcome of this one!
    I know the unit you have got from Maplin has had a few issues with getting the video files off but hopefully they have sorted it now! How many cameras are you going for overall?
  11. Patrick_c99
    Patrick_c99 Member
    198
    It's all seemed fine while I've been testing it inside. Just got to sort out power feeds and choose and fit cameras now. Il upload some footage when it's in and working.
  12. Cruiser89
    1,484
    220
    Cool... Well I remember hearing that the maximum file size you could pull off with a memory stick was about 1GB and you had to use a specific memory stick, is this still true?
    What have you thought in regards to power to the unit? Will you hook it up so that it's just with ignition or that it will work when the car is parked up? I can imagine this DVR using a lot of juice.
    Sounds like a good project. Would be ace if you had a camera for each side too, perhaps near your A Pillar that points out your side windows so you can get a view of the side of the car.
  13. Patrick_c99
    Patrick_c99 Member
    198
    It has a hard drive cady built in the bottom which I can plug straight into my computer to upload.
    I've got a large compacity battery which should hopefully be enough. If not il fit a small backup battery in the boot.
    The box can take up to 4 cameras. Which I'm just doing the front and rear for now and then will add the sides at a later date.
  14. Cruiser89
    1,484
    220
    Nice work... Look forward to seeing it!
