Fitting Hybrid
dale86 Dec 8, 2013
  1. dale86
    dale86 Member
    452
    15
    I'm gona be fitting a hybrid to my car in the next couple of weeks it's a 1.9tdi while I'm on I'll be changing oil and filter. Am I ok to use standard oil or is it ideal time to put something different in . Thanks
  2. DieselJake
    DieselJake Well-Known Member
    2,941
    748
    Depends if the term standard means Audi LongLife servicing haha (in which case stay clear of standard oil!), oil's surely the same regardless of turbo in which case any of these will do fine VW - Engine Oil - 507.00 - VW 507.00 motor oil.
  3. dale86
    dale86 Member
    452
    15
    Ok thanks very much.
  4. dale86
    dale86 Member
    452
    15
    Cheers thanks fir the reply
  5. adamss24
    adamss24 Well-Known Member
    4,584
    407
    You will need a map with the n75 duty cycle modified as the hybrid will make boost in a different way to a standard turbo. It might be ok as it is as the changes are not major...
  6. dale86
    dale86 Member
    452
    15
    Thanks Adamss24 it's the first port of call once all is fitted and running ok I'm trying to find someone locally to me who is good with diesel mapping.
  7. deano1978
    deano1978 different gear
    713
    81
    Did go ahead with this? Who did u map?
  8. dale86
    dale86 Member
    452
    15
    I havn t yet fitted will be in the next couple of weeks just sourcing the turbo oil feed pipe and gaskets. I was thinking on emailing black smoke to see if he could just do me a temporary map or see why he recommends.
  9. Jimmy TDI
    Jimmy TDI Pro Tinkerer Audi A4 Audi Avant Owner Group TDi
    1,320
    263
    Where are you?
  10. deano1978
    713
    81
  11. dale86
    dale86 Member
    452
    15
    I'm in Durham and that's the oil feed pipe I'm getting thanks. It's all coming together now just to find the time between me and my brother fitting me in his work to bolt it up .
  12. DieselJake
    2,941
    748
    I know the braided oil feed pipe can be a longer length but is there any other advantage with it?
  13. dale86
    dale86 Member
    452
    15
    It just says the fittings are more robust something about the ones on the car from factory are prone to been a pita when fitting.
  14. adamss24
    4,584
    407
    No advantages whatsoever, they only good when fitting larger/hybrid turbo's as the factory oil feed pipe will not be in the same place on a different turbo... The braided hoses also need careful tying and routing to stop them from chaffing onto sharp parts !
