will be buying a forge 007p in the next week and just fort ide ask if there is anything else to fitting them than simply removing the 3 hoses from the standard 1 and fitting them to the 007p???
As you've said, remove the three hoses from the old one and take it out then connect the three hoses to the 007P in the same way and it's fitted. Simple.
It's as DPM said, remove 3 hoses and reconnect, but the hardest bit is getting the factory hose clamps off, you need to have a decent set of cutters for the job, then a strong pair of hands to cut the buggers! Now replace them with normal screw type hose clamps and the rest is downhill...
