fitting fmic - any info please
mattm Sep 3, 2008
  1. 1animal1
    9,978
    thanks Sits..... ive been looking at a few on fleabay around the same size...... how easy would it be to run pipes between the existing SMICS, fitting one of these between (keeping the fogs)
  2. god_thats_quick
    2,507
    This has been bugging me for such a long time I finally got around to taking the bumper off my car today.
    I don't reckon this one has any hope of fitting without serious buggering around!
    I took some pics and did some measuring I thought was worth sharing, however I've realised I should have done even more now. I want to keep the fog lights and generally make it look totally oem so was just measuring the space in front of the air con radiator.
    I reckon you could fit a 56cm wide, 36cm tall and 60mm deep intercooler in without any cutting at all. Or a 47.5cm wide, same height and 70mm deep that's total space available.
    The standard ones cores are 17cm x 19cm x 85mm which was actually larger than I thought they would be.
    Loads more here:
    http://s4.photobucket.com/albums/y123/bparkes/Intercooler/
  3. S£
    S£ Member
    684
    Someones been a busy boy!! I suppose the hunt is on for a universal FMIC within your dimensions, I'll have a nose around see if i can find one!
  4. S£
    S£ Member
    684
    Slightly to small
    Slightly too big
    Maybe fit with a tiny bit of trimming
    I think that cutting will be required otherwise cooler will just be too small.
    It's good to get everyone's ideas on here, as we all know the S3 FMIC's are a rip off and if we come across a good set up our selves I'm sure quite a few will be interested!
    anyone else got any ideas or found a cooler? or comments on which of the above might be best?
  5. sitrials
    sitrials Member
    872
    try the intercoolerking on ebay that where i got mine 450x230x65 you can also get 450x300x76 from someone else to keep the fogs use 51mm pipe work instead of 63/76mm
  6. 1animal1
    9,978
    dont think from looking at those pics that it will be easy keeping the SMIC's lol, damn fine work taking those pics.....
    my thoughts are (which ithink ev1 else is at) that you need one big enough to make it worth replacing the SMIC's which dont look small
  7. god_thats_quick
    2,507
    I'm going to have another look (as soon as I get time) at what's available, Bell intercoolers do a core that's the right size but again I'm guessing after fitting end tanks etc. it'll get pricey. There are some on ebay that might be worth a look and if you could space the mount of the crash bar forward slightly (which I believe someone on here had done) then it might mean fitting a 76mm deep ~ 450 wide core would be pretty straight forward.
    I'm probably going to take everything apart again and either buy one of the cheap ones and see how it fits or make up some out of card / wood to see what will really fit and how.
    It's not hard to get an intercooler thats got a bigger surface area than the SMICs but it depends how much volume you want to increase, If you could get something that filled the 56cm wide, 36cm tall and 60mm deep space it's over twice the volume of the two side mounts!
  8. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    well my intercooler arrived this morning, and spent my lunch hour fitting it to the car and its all up and fits lovely just need to raise the hight a little to fit the pipe work in where the two side grills are, hopefully my pipe work will arive tomorrow then i can fit that and all will be done, so aslong as you brave enough and dont mind a grinder then you can fit a big cooler, supose it deppends what you want im not bothered about the fogs as they just blind people and arnt very functional where as a big front mount will actually serve a perpose
  9. keem
    keem Member
    123
    Kev, when your done, could you post exactly what you needed to fit your fmic? :)
  10. j4jon
    j4jon Member
    704
    Kev, which core did you go for in the end? Is it the one you posted above at 100mm thick? Can you post some pics?
  11. s3_kev
    2,002
    23
  12. j4jon
    j4jon Member
    704
    Thanks for that, what's the quality of the cooler like? I can't wait to see pics. How did fitting go with the depth of the core?
  13. s3_kev
    2,002
    23
    the quality looks good but guess time will tell but does looks good, fitting went ok i havent re-fitted the crash bar yet but its all cut ready so hopefully tomoz ill have the cooler at the right hight and fuly fitted in place with crash bar back on,
  14. jm-baker
    jm-baker Member
    230
  15. s3_kev
    2,002
    23
    well finally got my intercooler fitted up all level and in the correct position, now just the pipework to route through tomorow when i get to collect them from the local delivery office as they are in cabable of leaving my parcel where i asked as a safe place, ahhh.
    anyway heres some piccys of where im at so far;
    i used some 90 degree angle metal to make a solid level braket
    then i made up a suport bracket underneath to stop the cooler flapping around
    i then trimmed back the crash bar so the cooler would fit behind it
    the final look with the crash bar fitted
    i then had to trim the bumper insert where the fog grills would have gone to allow room for the pipework, im hoping to have this finnished tommorow or thursday as i still have loads of other little projects to do this week
  16. s3_kev
    2,002
    23
    oh yeah the top pic isnt me its my gimpy work mate who's helped me loads actually
  17. keem
    keem Member
    123
    well, it looks like the crash bar has lost its function.. ?
  18. s3_kev
    2,002
    23
    yep its lost alot of the strength but its not a crash bar for major acidents just minor dings to help stop further damage to the coolers such as air con condensor and radiator its not weakened the strength of the overall chassis or major crumple zone so im not concerened,
    plus if you notic i actually cut away alot more then necassary so if you was to trim away the bare essentials then there would be hardly any diference in strength
  19. keem
    keem Member
    123
    yep, i see.. just waiting for the pics with all the pipes and bumper mounted now :)
  20. mattm
    mattm BLACK EDITION
    184
    kev sweet pics, cheers for the effort to show us :)
  21. s3_kev
    2,002
    23
    so got my pipes to day except the 90 degree elbow reducer from 3 inch to 2.5 inch but as you can see in the pics below its very nearly there now, oh and need some nice clamps to hold the pipe and hoses together, the pipes i got were the perfect size to so no need to mess around chopping to size if anyone is wanting to make the same cooler
    the large gap between the pipe and the joiner above is where the 90 degree elbow has to go
    and then its the same on the other side
    then it looks like this with the bumper back on
    so here is a list of what you need;
    -ths type 4 intercooler
    -viper performance hoses and pipes
    ~ 2* 90 degree 3 inch polished pipe
    ~ 2* 90 degree 3 inch hose
    ~ 2* 90 degree 3 inch to 2.5 inch reducer hose
    ~ 2* 2.5 inch hose joiner
    ~ 2* 3 inch hose joiner
    ~ 2* 3 inch hose 120mm long, i used one 250mm hose chopped in half
    ~ 10* 3 inch hose clamps
    ~ 2* 2.5 inch hose clamps
    http://www.viper-performance.co.uk/index.php
    http://www.thsperformance.co.uk/
    http://www.powerengineering.co.uk/mikalor/
  22. j4jon
    j4jon Member
    704
    Looking good. So how much has it all cost then?
  23. s3_kev
    2,002
    23
    havent added all together yet but just a shade over £300
  24. keem
    keem Member
    123
    Thanks for all the info Kev, you just saved me 300+ (i was thinking about going for the forge kit earlier) :)
  25. S£
    S£ Member
    684
    Originally i didn't want to cut the crash bar but after what you said about it, i'm now not to bothered i think, as for the fogs I'm still not sure, if a cooler is fitted with smaller pipes, i think someone mentioned 50mm, will the fogs fit in then?? As for the work you've done it;s great to actually see a good guide for people to go by other than the Forge kit!
    THANKS!!! :kiss:
  26. s3ollie
    s3ollie Member
    762
    the fogs fit with the forge kit
  27. s3_kev
    2,002
    23
    you could always run the pipe work up side down as danclarke has on page 1, not sure if smaller pipe work would work onthat size cooler as its the length of pipe you need to join to the bend then theres th length of th bend in the pipe think to mount the cooler the normal way up the only awnser would be to use a smaller cooler but then your not going to get the full benefit as surface area isnt going to be increased as muchthus less cooling
  28. jim s3
    jim s3 Member
    321
    copy cat:nyah:
  29. s3_kev
    2,002
    23
    sorry mate wanted a fmic for a while but wasnt sure how to go about it then i saw yours, yours looks like you have more polished pipework though,
    i hate people who copy one off ideas to so i hate myself, but it looks soo good just had too
  30. keem
    keem Member
    123
    Do you have pics with the last hoses fitted?
  31. s3_kev
    2,002
    23
    havent recived them yet
  32. jim s3
    jim s3 Member
    321
    you will be painting your badges next lol
  33. s3_kev
    2,002
    23
    na i like it chrome lol, suits the wheels and mirrors lol
  34. keem
    keem Member
    123
    Have you recieved your last hoses?
  35. s3_kev
    2,002
    23
    yeah they arrived today actually just waiting for some jubilee clips that i should have for tomorrow then i shall have the job all finnished
  36. beeitch
    beeitch Member
    66
    Just a few pics, i hope it could help you.
  37. god_thats_quick
    2,507
    Looks like you have an oil cooler or two there chap, got any more information or is it just because it's actually warm occasionally in Spain?
  38. FazS3
    FazS3 Member
    867
    just out of curiosity,what are the gains to be had from fitting a larger intercooler?i have bin looking at the forge ones but they are very very pricey
  39. beeitch
    beeitch Member
    66
    Hi, yes on passenger side there is a 13 row oil cooler and also we have installed a fuel cooler (diesel).
    Obviously Spain is warmer than the UK, so we needed to change SMIC to FMIC in order to improve performance with the new hybrid turbocharger. In the other side, diesel cooler prevents injection lack when diesel temperature begin to rise up.
    Sorry for my bad English
  40. keem
    keem Member
    123
    whats the status, kev?
