FITTING BRAKE LIGHT SWITCH ON 2002 A4 ANY IDEAS????
codrock Jul 21, 2009
  1. codrock
    codrock Member
    50
    IS IT EASY TO DO OR DO YOU NEED TO HAVE THIS DONE BY A MECHANIC??
    ANY HELP IS REQUIRED
  2. docurley
    4,069
    85
    you have to remove the lower dash on the drivers side 4 screws I think and then you will have access to the brake switch which is just a twist and remove action and then unplug it.
    Make sure when you put the new one in you do not move the brake peddle or it will set incorrectly.
  3. quattrojames
    14,050
    573
    This was only asked yesterday! The search function is your friend ;)
  4. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    No its real simple, the new break switches are improved designed, just to the left of teh clutch peddle you will find the plug switch your looking for, unplug the old one from the loom and twist out, push and twist the new one in and click into place, plug back in and off you go,
