Fitting BI-XENON s3 headlights to a 2009 audi a3
Waqi_92 May 28, 2012
  1. Waqi_92
    Waqi_92 New Member
    20
    9
    Hey there people! Proud owner of a 2009 audi 1.9tdi a3
    It came with the standard halogen headlamps which look okay but i wanted mine to look special, ive bought a set of s3 bi-xenon headlights, balasts and d1s 6000k bulbs
    From what i have worked out, i need to get a audi 10pin to 14pin converter cable ( KUFATEC springs to mind)
    and wire two wires into the CEM under the steering wheel, after which i need it coded for bi-xenons
    Is anyone in the birmingham area available to code my car to bi-xenon? beer tokens avail ;)
    Also, i was wondering, if i obtained an empty 14pin plug (i have the part number) , would it be possible to remove the wires from the original plugs and place them in the 14pin plug?
  2. mjr901
    mjr901 Guest
  3. Ash187
    7,522
    759
    Hi Mate,
    i can do the install for you, also regarding the 14 pin connector yes it can be done though you would also need to order 2 repair wires to make up for the new pins that need to be wired in.
    PM me if your interested.
    Ash
  4. Waqi_92
    Waqi_92 New Member
    20
    9
    PM'd you dude :) one garage offered to do the wiring, fitting and coding for £150 all in? seem a little sceptical as to using them...
  5. Scotty1987
    Scotty1987 New Member
    Ash can you do install for me contact me in 07581260270
