Fitting a ITG CAI on a S3
coreythorny Apr 3, 2013
  1. coreythorny
    coreythorny Active Member
    463
    74
    Could anyone please tell me how long it would roughly take to fit the intake in question?
    mine turned up from a member today :D just wondered if I had time to fit it tomorrow after work as it quickly gets dark. Not had chance to pop the bonnet and work it out.
    It looks a simple job. Just plug and play? Is the airbox bottom half fitted in with rubber grommets like the engine cover also?
    thanks for any advise.
    Also I presume it's a easy enough job to fit the standard back on?
  2. Jonni
    Jonni Active Member
    241
    33
    Heard the clip on the turbo pipe is a struggle
  3. coreythorny
    463
    74
    is it a spring retaining clip like the one to airbox?
  4. Jonni
    Jonni Active Member
    241
    33
    Not sure tbh use the search bar
  5. Marc.
    Marc. New Member
    Took me about an hour to do mine, a steady plod at that, sipping tea and yapping to mates etc.
    The turbo inlet wasn't too bad, if you have flexy or pivot sockets its a breeze. It gets a bit right around the filter cone / last bend area and its worth taking the time to position the clips for max clearance. It's an easy ish job, just a bit fiddly as you'd expect.
  6. coreythorny
    463
    74
    Cheers Marc. Might just leave it as it will be coming off in a week or two again, then back on again.
    see what the weathers like lol
  7. Marc.
    Marc. New Member
    No problem! It will be much easier when it's not dark - you're guaranteed to drop a clip or screw into the abyss if you try it in the dark, that's usual case for me anyway lol.
  8. elrao
    elrao Member
    378
    AmD charge £50+vat to fit their CAI which would imply about an hour.
  9. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
  10. JamesS4cab
    JamesS4cab Well-Known Member
    1,190
    94
    Took me about 30 mins - most of which was spent doing the clip on the turbo up! Getting the old pipe off the turbo was quite tight as well and you have to pull harder than you would think (ooo er missus). Position the clips in the right place to access the bolts before you start doing them up - a little bit of thought saves shed loads of time!
  11. GNJ_Motorsport
    GNJ_Motorsport Site Sponsor Site Sponsor
    660
    188
    43
    It is easy Corey, turbo pipe can be a pain but not that bad. We would charge an hours labour to do it.
  12. Smiffi
    Smiffi Member
    156
    That clamp tool Red put a link to would come in really handy for removing the oem clamp on the turbo pipe. I'm relieved the CAI came with jubilee clips! Much easier!
  13. br20vt
    br20vt Active Member
    195
    56
    It took me around 40minutes, most of this time was spent trying to get the engine cover off lol, once that was off it was simple to do. Just a bit of hand squashing for the turbo pipe.
  14. coreythorny
    463
    74
    Doesn't the cover just pull off? No bolts etc?
  15. coreythorny
    463
    74
    Ok find a couple how-to's for similar kits etc, happy days.
    Just before I get stuck in, does the standard spring clip off the turbo inlet (the one which causes the swearing lol) get re-used on the silicon joiner from the ITG kit or is it replaced with a jubilee clip?
    Reason is I didn't get a clip for that joint (it came assembled near enough), so just want to see if I need to go pick up some clips before I start taking it all apart.
    Thanks.
