Fitting a decat
steady jay Apr 21, 2011
  1. steady jay
    steady jay Member
    184
    Well I spent 2 days attempting to fit a decat on my a4 1.8t, just had a little test drive come back home and discovered a little bit of smoke coming from the gasket next to the turbo. Would this be bedding in the new gaskets or is it just f**ked?
    Cheers all Jay
  2. Bradderz_1988
    3,986
    261
    Were you get the de cat and gaskets from and are all the nuts tight also I would bolt it to turbo first then downpipe.
  3. steady jay
    steady jay Member
    184
    Gaskets are from Audi, pipe is from eBay, nuts are as tight as humanly possible considering it's such a small place to work with.
  4. Bradderz_1988
    3,986
    261
    I'd get two gaskets on it if you haven't already got two on that is ??
  5. steady jay
    steady jay Member
    184
    Don't think I'm following, 2 gaskets on the each end seems daft.
  6. Bradderz_1988
    3,986
    261
    No just 2 on the turbo side the downpipe has one, if you put 2 on the turbo side it will butt both gaskets up creating a tighter gasket in theory.
