Fitting a boost gauge
DamoS3Q May 24, 2004
  1. DamoS3Q
    DamoS3Q Member
    90
    Morning all!
    How difficult is it to fit a boost gauge? I want one! Any ideas where to fit the unit?
    Also does anyone know if this voids the Audi warranty?
    Cheers, /ubbthreads/images/graemlins/hug.gif
  2. Markb
    Markb Active Member
    2,139
  3. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    [ QUOTE ]
    Damo said:
    Morning all!
    [/ QUOTE ]
    Damo
    I got mine fitted by a garage because I didn't know what line to tap into for the boost gauge to run off of. I'll take some photos tonight to give you an idea of what you have to do.
    Grant
  4. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    Fuel regulator hose..........very easy!
  5. Grant
    1,206
    118
    [ QUOTE ]
    [/ QUOTE ]
    Easy when you know which one you have to cut! No so easy if you were like me and didn't have a clue!
  6. excursion
    excursion Member
    740
    I wouldn't reccomend using the FPR hose. It's only slight, but there is a latency induced by tapping into the hose. That is the reason the hose is so short and direct to the FPR.
  7. Mike.M
    2,477
    169
    I used WAK'S site as I did not know until then /ubbthreads/images/graemlins/beerchug.gif
    Where is yours tapped into Mark?
  8. excursion
    excursion Member
    740
    The DV hose mate /ubbthreads/images/graemlins/smile.gif
    Your's being a later car may have some additional vacuum lines you can tap into.
  9. Mike.M
    2,477
    169
    What......the recirc pipe?
  10. excursion
    excursion Member
    740
    [ QUOTE ]
    [/ QUOTE ]
    Aiiiii [​IMG]
  11. Mike.M
    2,477
    169
    So many hoses /ubbthreads/images/graemlins/cry.gif /ubbthreads/images/graemlins/crazy.gif /ubbthreads/images/graemlins/shocked2.gif
    Mines out at the moment as I had that warranty work done.........waiting for a while before it goes back in to see how healthy she is.
  12. excursion
    excursion Member
    740
    If you want a hand we can have a look next time I'm down.
  13. PaulRS3
    PaulRS3 Well-Known Member
    1,209
    141
    Thats the Fuel pressure regulator (FPR) line.
  14. MingBluS3
    MingBluS3 Member
    360
    How does that work then?
  15. Grant
    1,206
    118
    Why does Excursion not recommend tapping off this line?
  16. excursion
    excursion Member
    740
    If you get a leak on the FPR line there is potential for det and engine damage.
