Fitting a boost gauge mount
LukeTripod87 Apr 15, 2011
  1. LukeTripod87
    LukeTripod87 Active Member
    373
    52
    Hopefully one of you have done this before! Im after fitting a boost gauge into my drivers side air vent using this VW Accessories & Styling , Worldwide Mailorder
    How would I get the vac hose into the engine bay and where do you reckon is the best place to connect the pipe to? Any help would be much appreciated
  2. shanejess
    shanejess Guest
    take off fuse box cover, remove containment nuts which you can see plus under dash nuts and remove drivers side under dash, if you can loosen your wind screen wiper nuts do so and remove plastic full length cover, these are hard to remove nut, that is and sometimes siezed, it doesnt matter, get an old metal coat hanger ant thread through inside of car to bay, tape on use a little washing up liquid to pull through freely,i T peiced to 007 vale tubeing. cheers shane.
  3. LukeTripod87
    373
    52
    Cheers for that I'll give it a go in the next week or so.
  4. Westy
    Westy Well-Known Member
    17,443
    1,105
    Get some pics up Luke as I have a gauge and air vent holder on order. Should arrive next week
  5. Westy
    17,443
    1,105
    Dont worry about the pics, mine arrived this morning and i'm just finished fitting it ;)
  6. Westy
    17,443
    1,105
    Oh ******** I've wired it in wrong! The back light comes on when the ignition comes on but then goes off when the lights are turned on and it's brining up a dash error telling me a bulbs blown!
    Think I'll tackle that in the morning :banghead::banghead::banghead:
  7. A3 T
    A3 T Lord Of The Rings
    1,077
    15
    I've got a gauge that I'm planning on fitting into a pillar pod.
    Did you route the hose the way shanejess suggested?
  8. Westy
    17,443
    1,105
    Yes but I managed to do it without removing the lower dash, but it would have made things easier if I had.
    I also removed both wiper arms and the whole scuttle tray and removed the wiper mech so I could access the plastic box on the drivers side, under the wiper arm. I removed this box so I could feed the hose through. I then drilled a hole in the box and poked the hose through that.
    Oh and I also plumped the t piece into the FPR pipe and not the DV one like Shane mentioned.
  9. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Just wondering have you revved the car a bit when you took that photo because your vacuum should be around 21 in.HG on idle.
  10. Westy
    17,443
    1,105
    I think I did but at idle it's only sitting at around 17hg!
  11. S3 Nattie
    1,599
    If that was on cold start thats about right. On warm idle it should be around 21-22.
  12. HTC
    HTC Active Member
    3,428
    9
    Just a quick pic for the original poster showing the box under the plastic scuttle. You can see the pipe for my boost gauge. I went through the rubber grommet and added some silicone.
  13. Westy
    17,443
    1,105
    Yeah that was a cold start nath, phew.
    HTC, I used your old thread with that same pic on, cheers. The plastic box on the S3 is slightly different though.
  14. HTC
    HTC Active Member
    3,428
    9
    Thanks for letting me know. Good to see some of my old pics still go to some use.
  15. S3 Nattie
    1,599
    Thats actually a good place to feed the hose into the car. I feed mine through the little hole were the bonnet catch goes through by the drivers side bonnet strut. Was a bit awkward getting it through but easy to route it to the gauge once inside the car.
  16. Westy
    17,443
    1,105
    I bookmark any pages that I think will come in handy one day and yours was one of those. I thought you'd left the audi scene as not seen you post here much?
  17. LukeTripod87
    373
    52
    Westle where did you get your vent mount from as that is for facelift S3's like mine whereas the link I posted was for pre-facelift?
  18. Westy
    17,443
    1,105
    Same place as you mate. There were two types, 1 for pre face lift and 1 for post.
  19. A3 T
    1,077
    15
    I attempted to fit mine today but i fell at the first hurdle.....lol
    My wipers wouldn't come off. I tried the pliers trick....etc but they wouldn't budge, so i gave my mechanic a call and he is going to get them off with a puller tomorrow :)
    I'm really not looking forward to digging around under the dash :(
  20. HTC
    HTC Active Member
    3,428
    9
    I've moved to Thailand so I don't get much chance to post here these days but I like to read and post on the forums when I get time. I still have my car but it's just sitting in a garage in deepest darkest Sussex. Hasn't been driven in over a year now. I was thinking of having it shipped over here, but the costs wouldn't make it worth it. You don't see any A3s or S3s over here.
    Glad to hear you guys are still enjoying your cars.
  21. Westy
    17,443
    1,105
    On my drive into work today I noticed that the vac wont register any more than 16 in hg when idling. Does this mean I have a leak somewhere or just a cheap ass gauge? ;)
  22. shanejess
    shanejess Guest
    didnt like saying westle but your gauge looks as cheap as. i wanted one more accurate so paid a bit more, yours you have to guess a little because of the 5 psi stage markers. looks ok though its fit well.
  23. Westy
    17,443
    1,105
    It does look a bit cheap but I wanted one that matched the interior/orignal dash so went for that one. It's a lot better made than it looks, and wasn't super cheap. I dont mind a bit of guess work, I only bought it so I could keep a roungh eye on what boost is doing on my car.
  24. A3 T
    1,077
    15
    Does it matter how long the hose is from the diverter valve to the boost gauge?
    The reason i ask is that after removing the the wipers i couldn't lift the scuttle tray, so i ended up using the same hole i used for my sub.
    The only problem is that the hole is on the passenger side of the car so i need to run a hose along the back of the dash and use a joiner to join the two hoses under the passenger foot well.
    Another question I've got is....
    Do we need to use a specific type of hose or can i buy some from an aquatic shop?
    Thanks guys ;)
  25. Westy
    17,443
    1,105
    In my fitting kit I got some plastic hose that needed to be attached to silicone at the end so it fits the t piece. I had half a metre of black 3mm silicone that I used on the end of he plasic hose so I could route it round the engine bay how I wanted.
    Some plastic hose isn't up to the job and will melt so make sure you get something that can stand reasonably high temps.
  26. Syvo
    Syvo IF IN DOUBT GO FLAT OUT
    1,338
    22
  27. Westy
    17,443
    1,105
    Get some pics up once it's done Paul.
  28. Syvo
    1,338
    22
    no worries will put on list lol with pics of boost guage and oil catch can.
    got few bits do over next couple of weeks remake the sill guards black with quattro in yellow
    respray the wingmirrors
    paint callipers
    fit radio adapter so can get radio working
  29. Westy
    17,443
    1,105
    You want to jump on the late night mechanics band wagon mate, it's the best time to work ;)
  30. Syvo
    1,338
    22
    haha dont tempt me it used to be like that untill the rents filled the garage with **** so i carnt work in there now just waiting to get all stuff back out to start the late nights again.
    bro does most of the mechanical i do the body and trim not very good with mechanical side leave that to the people that know lol
  31. Westy
    17,443
    1,105
    My old mans just painted the garage floor and he wont even put his car in there at the moment let alone let me put a jack/axle stands on it! Late night mechanics has taken a slight back seat :(
  32. Syvo
    1,338
    22
    bad times will be dry in few days then can start again i need to build a storage shed at the back of the garage still waiting on step dad get the gear will only take me a weekend dig it out pour concrete build storage shed and render the thing.
    i know he taking his time stop me having the garage lol
  33. A3 T
    1,077
    15
    Thanks mate ;)
    I didn't even think about the heat, I was thinking more about the hose collapsing under pressure.
    Yeah mine come with about a metre of hose (don't think its heat resistant) but i think ill need to add another metre to it.
    I thought the hose on top of the dv...etc was 4mm?
  34. Westy
    17,443
    1,105
    My memory is so bad and the silicone I had in the garage was over a year old and didn't have any size printed on it so I can't remember the exact size. 3 or 4mm
  35. A3 T
    1,077
    15
    I went out on a hunt for some cheap vac hose but they all seem like they will collapse .
    I've looked at both the silicone and the pvc hoses (like the windscreen washer hose) but none of them seem as good quality as the pvc one that come with the gauge. :shrug:
    help....lol
  36. Westy
    17,443
    1,105
    Did you get some with the gauge? If so you should be able to use that then connect some 3mm silicone to the end of it to extend it. You need to put silicone on the end of the plastic hose anyway to be able to use the t-piece into the DV/FRP line.
  37. A3 T
    1,077
    15
    Yes mate, the gauge come with some good quality clear pvc hose. its just not long enough.
    The problem I'm having is I cant seem to find any hose that i can add to it that's up to the job.
    They all seem like they are going to collapse under pressure :(
  38. AGU-TURBO
    AGU-TURBO Audi a3 1.8t AGU
    616
    i bought some blue silicone vac hose from ebay. somthing like £2 a metre there isnt realy alot of preasure so don't worry about spending a fortune on it
  39. A3 T
    1,077
    15
    I don't suppose you've got a link to the one you bought have you mate?
    I've been to quite a few shops now and the quality have been really bad (very thin) do I'm a bit hesitant about buying it online because ill just be taking the sellers word for the quality.
  40. AGU-TURBO
    616
