Fitting 195/55/15
Stuart35205 May 12, 2013
  1. Stuart35205
    Stuart35205 Member
    108
    Hi , is anyone running these on the standard alloys ? Does anyone know if they will fit width wise etc? Currently running 175/50/15 but there quite a harsh ride! Regards Stuart
  2. s8craig
    1,753
    56
    Sizes
    OE tyre sizes are underlined. These, along with 155/65R15 and 165/65R15 are the only tyres that are truly 100% compatible and listed in the CoC document.
    15"
    155/70
    165/65
    175/55
    175/60 (reference size)
    185/55
    185/60
    195/50
    195/55 - identical rolling circumference to 205/40R17
    205/50
    205/55
    225/50
    16"
    175/50
    175/55
    185/50
    195/45
    195/50
    205/45
    215/40
    215/45
    225/40
    17"
    195/45
    205/40
    205/45 - this may work, it may catch. Check!
    215/40 - as above, especially at the rear
    215/35
    225/35
    245/35
    18"
    205/35
    215/35
    225/35
    225/30
    If it's not on the list, it will not fit without work / rubbing: this includes 205/55R16, 195/65R15 and 225/45R17. Do not buy it without your eyes wide open.
  3. Stuart35205
    Stuart35205 Member
    108
    Hi Craig I have read that article before , cheers I was just wondering if the had been tried & if so did they improve comfort as we all know these cars are exceptionally firm!
    Regards Stuart
  4. s8craig
    1,753
    56
    General rule is thicker the rim, the better the ride so if you can add 5mm to the wall then it will be slightly better, but you also increase the tire width which will incur a fuel penalty as your rolling resistance will increase slightly.
    I noticed a drop in fuel economy and acceleration when I went from 16 to 17" wheels as I increased the weight and rolling resistance.
  5. Stuart35205
    Stuart35205 Member
    108
    I had heard many comments on the 17 inch wheels making the ride firmer but they do look good tho. I will have a look in to it abit more it would be interesting to know if they will fit on the standard 15" alloys due to their width ?
