Fitted new seats now airbag light on.
Ian_tdi Jan 10, 2012
  1. Ian_tdi
    Ian_tdi Member
    306
    Fitted my new seats yesterday, from a mk2 tt and the wiring plugs were different to those on my a3 so as expected the airbag light came on.
    If I changed the plugs from my original seats onto the new ones cure this? Or can it be turned off via diagnostics? The seats are lovely and far outweigh the inconvenience of the airbag light being on but I am aware of the new mot laws coming into pal e meaning this would be a fail.
    Any help greatly appreciated!
    Ta
  2. welshwoody
    welshwoody Member VCDS Map User
    433
    10
    Might not be the same as mine but I remember when I changed my seats I had a warning light come on, I was advised on here to take the car out for a spin round the block which did the trick, light went off after a few hundred meters, yards, whatever.
  3. Ian_tdi
    Ian_tdi Member
    306
    Oksweet cheers, will try changing the plugs over and see if that works.
    Many thanks
  4. NHN
    29,282
    1,692
    If they're the same pins on the end then yeah, but you need to also make sure the 3 pins are also round the right way as the previous so pin 1 to pin 1 etc
  5. Ian_tdi
    Ian_tdi Member
    306
    Yep will do.
    Many thanks.
